- Joined
- Sep 28, 2002
- Messages
- 39,799
Quote:
Quote:
There was a UOA not long ago where the filter was changed every other OC and the UOA was stellar, albeit it was a honda uoa. Terry also approved the filter change interval and also made the comment that the filter becomes more efficient. I would definately follow his advise.
That certainly may be, but I will stick to changing my filter at the time of the oil change. At some point the efficiency will go down. Does the UOA predict when this will happen?
Surely do whatever you feel is right. I've personally studies 10k old filters and they weren't nearly saturated. What you don't perceive is the capacity of a common filter in a modern combustion environment. The holding capacity is well in excess of any factory recommended level if adhering to the factory format.
The media efficiency never goes down ..it only improves. What can occur, and this is still way out there in terms of when this will occur, is that differential pressure across the media will cause whatever bypass mechanism to be employed. Now this occuring due to loading is a very substantial mileage. Now it will exacerbate cold start/oil pump in relief/transitional peaks/prewarmup type bypass activity ..but this too is highly over rated in my observations for how often it happens ..and how long it lasts. Even with a 10k old filter with 20w-50 oil in a subfreezing starting temp I didn't reach the bypass threshold and had very little static PSID after warmup. Even in a "half the distance to the goal line" type deminishing return for mileage added ..this filter, a PureOne, would have been good for 15k.
FWIW
