I am going to be installing an oil pan heater on my 1993 Suburban within the next month. I have read through the archives on this site, and I still don't have all my questions answered.
My 'burb has a 350 with a 5 quart oil capacity, with one of those quarts being in the filter. So, the Oil pan should have no more than 4 quarts in it at any given time.
What is the appropriate sized heat pad for this size sump? I want ensure I don't use a pad too hot for the capacity, to prevent the oil additive package from breaking down.
Secondly, I know that Wolverine pads are talked about to a great extent. I have seen "Polar Pads" at the local Canadian tire store. Are these pads any good, or should I stick with a Wolverine? The are slightly different in dimension from Wolverine, but are rated at about 14 watts per square inch just like the Wolverine pads. Does anyone know any Wolverine pad dealers in Ontario, Canada?
