What did this engineer warn you about, Harry?? The gasket size appears a little different.
Quote:
My Civic calls for the Eao20 filter.It has a higher bypass pressure than the larger Eao36.
Well, Harry, let's just explore this a bit here.
If you used either of those filters from Wix:
(Eao36 xref'd)
Part Number: 51347
UPC Number: 765809513471
Principal Application: Ford Courier (72-82), Hyster, Komatsu, Merc. Bobcat (75-79), Pinto (75-79), Thermo-King, Yanmar Excavators
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.828
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI:
8-11
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 325
Max Flow Rate: 9-11 GPM
Nominal Micro Rating: 20
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.734 2.430 0.226
Eao20 xref'd
Part Number: 51334
UPC Number: 765809513341
Principal Application: Acura (88-05), Chevrolet (85-88), Dodge (91-96), Ford (88-96), Honda (72-05), Hyundai (89-07), Isuzu (85-04), Kia (01-07), Mercury (87-91), Mitsubishi (89-98), Subaru (87-07), John Deere, Kobelco, Komatsu, Kubota, Onan, Toro & Yanmar Diesel
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.194
Outer Diameter Top: 3.252
8-11
Beta Ratio: 2/20=22/40
Burst Pressure-PSI: 280
Nominal Micro Rating: 19
Gasket Diameters
Attached 2.475 2.173 0.233
Now those two xref'd to Donaldson
P552849 (51347)
Lube Filters Product Attributes
A - OD (Inches): 2.96
B - Thread Size (Inches): M20 X 1.5
C - Length (Inches): 3.4
D - Gasket OD (Inches): 2.7
E - Gasket ID (Inches): 2.33
Relief Valve Setting (PSI):
11 - 17
Anti Drain Valve (Y/N): Yes
Product Type Description: LUBE SPIN-ON FULL FLOW
Primary Application: FORD, MAZDA
P550162 (51334)
A - OD (Inches): 3.18
C - Length (Inches): 3.39
D - Gasket OD (Inches): 2.5
E - Gasket ID (Inches): 2.11
11-17
Primary Application: Kubota 70000-15241
In Purolator L14459 (51334)
Height: 2.95
Type of Filter: Spin-on
O.D.: 3.15
Relief Valve P.S.I.:
12-15
Threads: M20x1.5
L20073 (51347)
Threads: M20x1.5-6H
Height: 4.74
12-15
O.D.: 2.98
If you have ever bought a Donaldson or Purolator ..did you experience any "fear" due to the bypass setting being so much higher then the WIX???
What is common to all three of the above filter offerings? They all share a common bypass valve setting for the manufacturer. Why is this? What does the bypass valve do? What does the bypass valve setting do? Not in functional terms ..but in design/conceptual terms.
The bypass valve protects the engine from oil starvation
The bypass valve setting protects the filter media from too much PSID
That is, if you see a high bypass valve setting ..it is assured that the media is beefed up to withstand it. Conversely, if you see a lower bypass vavle setting, the media cannot withstand that much differential pressure. This is exclusive of what happens to flow when this occurs. Or rather ..what happens to flow to allow this to occur and what role it plays in it.
I'm speaking generically here, Harry. There can, and are, engines that spec a certain bypass valve setting in their scheme of things. VW/AUDI is one. I'm sure there are others ..but as you can see, WIX, Purolator, and Donaldson view all the respective applications ..as vast and diverse as they may be, to fall under ONE bypass valve setting ..yet each bypass valve setting is different for all of them.
Quote:
Given that the filters are reluctant to going into bypass mode
Reluctant? They don't have a choice in the matter. Either conditions dictate that they start opening ..or conditions don't
What you should appreciate is/are the conditions that dictate the action.
