427Z06,
My Subaru (both turbo and non-turbo), now calls for the EAO-12 oil filter, which is the shortened version of the EAO-13. The 3.0L, six cylinder Sube engines call for the much larger EAO-20, as did the four cylinder motors in the past. The wider EAO-20 is a tight squeeze, but I'm not changing it very often so I don't mind.
As I recall, many of the older Hondas/Acuras called for the EAO-20, or the even longer EAO-36. However a check shows that the EAO-36 is not simply a longer version of the -20 anymore, so I wouldn't consider that substitution.
I've spend a few hours going through all the possible filter substitutions with these new Amsoil EAO filters, if U still have questions....
Harry,
Donaldson claims a big difference in the ability of this nano-fiber media to flow oil at low temps. As I recall from their charts, you could go about 15F lower before the bypass valve would open on a diesel running SAE 15w-40. My observations with the EAO filters in passenger vehicles, using a variation of this same media, would tend to support this....
TD
