- Joined
- Jun 2, 2003
- Messages
- 23,591
A friend's evap system started leaking fuel around the purge valve solenoid valve. He replaced the valve, because the car was idling poorly and he suspected that the valve was the cause of the leaking and poor idle. The leaking issue did not go away. Upon closer inspection he found out that the evap canister appeared to be clogged. What could have clogged it? Certainly not fumes, so it's reasonable to assume that gas got sucked into the evap system. The evap system should not contain any "wet" fuel, but only fumes, correct? Any idea what's going on?
