KTM 1190 Adventure oil viscosity?
by vfrkent - 04/03/20 11:42 PM
2011 Kia 2.7L Theta Hav. Pro DS
by twouvakind - 04/03/20 10:40 PM
Replacing Rusted Fuel Lines
by 92saturnsl2 - 04/03/20 10:35 PM
(3) 5-quart + Fixd ODB-II reader for $40.50+tax
by wkcars - 04/03/20 09:57 PM
Tesla Crushing It
by JeffKeryk - 04/03/20 08:42 PM
Pacific Valley in Big Sur with the E46
by SLO_Town - 04/03/20 08:33 PM
I drove a Delta pilot to the airport today
by 14Accent - 04/03/20 07:41 PM
ALUMINUM BLACK™ metal finish touch-up pen
by vavavroom - 04/03/20 07:28 PM
Strut leak
by ford46guy - 04/03/20 06:30 PM
Orifice tube backwards, now can’t reach it
by gallydif - 04/03/20 06:14 PM
Bone creeper?
by JHZR2 - 04/03/20 05:58 PM
Wrangler TJ Engine Oil
by TJim - 04/03/20 04:53 PM
Virgin XG3600 cut open
by bullwinkle - 04/03/20 04:30 PM
Windows Update and Shutdown update confusion
by simple_gifts - 04/03/20 04:29 PM
Mildew Smell in AC System
by painfx - 04/03/20 04:17 PM
M1-113A CUT OPEN
by 53' Stude - 04/03/20 03:56 PM
MC FL500S 7,000 miles CUT OPEN
by 53' Stude - 04/03/20 03:43 PM
USS Theodore Roosevelt
by BMWTurboDzl - 04/03/20 03:42 PM
2020 Subaru Forester Base
by wagsrk08 - 04/03/20 03:41 PM
New Rislone Hy-per Fuel Product?
by Jackson_Slugger - 04/03/20 03:38 PM
Peacock, Agauth12, PatGN, Fjordman95, TJim
71086 Registered Users
34 registered members (Alfred_B, bennyG, bachman, blufeb95, Alaskanmont, 928, 3 invisible), 1,317 guests, and 19 spiders.
Topics303,554
Posts5,237,347
Members71,086
Page 1 of 3 1 2 3
DIY Headlight aiming - Some Aiming Specs. #766145 11/11/06 11:04 AM
J
Jim 5 Offline OP
J
In the spirit of DIY maintenance of BITOG, I thought this might help someone, found this quote:
Looking in the Little blue Bosch book, the aiming dimensions are 10 cm below the headlight center height at a distance of 15 Meters; along with centering on the longitudinal axis. Foglights are 20 cm lower than center.
Some more information and diagram giving better explanation here (with non-metric measurements):
http://www.popularmechanics.com/automotive...html?page=3&c=y
If anyone can add to this guide, I would appreciate it.
Jim A
07.5 GMC Sierra 2500HD LMM Rotella 15w-40
09 Odyssey EX-L CT 5w-20
66 Bronco QS 10w-30
08 BMW K1200S Rt 15w-40
08 Pitster Pro X4 Rt 15w-40
Re: DIY Headlight aiming - Some Aiming Specs. [Re: Jim 5] #766146 11/11/06 06:55 PM
G
Greggy_D Offline
G
Linky no worky for me.
Greggy D.
Re: DIY Headlight aiming - Some Aiming Specs. [Re: Greggy_D] #766147 11/11/06 10:11 PM
Q
Quickbeam Offline
Q
Me neither but here's some info from Dan Stern's website on aiming: http://tinyurl.com/yhdm9z
Re: DIY Headlight aiming - Some Aiming Specs. [Re: Quickbeam] #766148 11/11/06 11:10 PM
J
Jim 5 Offline OP
J
My apologies, not sure why it didn't work. Let me try again:
http://www.popularmechanics.com/how_to_central/automotive/1272456.html?page=3
An excerpt:
"Park your car in front of a light-colored wall in a dark spot indoors, or outdoors at night. Position the car so that the headlights are 25 ft. from the wall, and be sure the car is parked at right angles to the wall. Measure the height of the center of the headlights from the ground. Make a line on the wall with a marker or masking tape at this same height. Now mark a pair of vertical lines directly in front of each headlight. With the adjustment thumbwheel, you can now slue the beam up or down and left or right. If you have trouble visualizing one beam because the other obscures its light, try pulling that lamp's connector, or just covering it with your jacket.
The specific numbers vary with each vehicle manufacturer, but at the very least, the left and right beams should be the same with respect to their individual centerlines. The cutoff line should be just below the line at the headlamps' center. The kickup to the right of the beam should start just to the right of the centerline. Do all the adjusting with a trunkful of luggage, a tankful of gas and a warm body in the driver's seat.
Many late-model cars incorporate a small bubble level directly into the headlamp housing. Observing the level will help you to make adjustments when you are aiming the light beam. Remember that this is only an initial adjustment. You'll still need to visualize the beam on a wall to trim out the correct alignment. This is because manufacturing tolerances don't always place the filament in the lamp in exactly the same position relative to the lamp's metal base--which can make the beam's alignment quite different when the lamp is replaced. The level will let you make headlamp adjustments when you have to drive a heavily loaded vehicle. Check the settings on the bubble levels, load up the trunk, reset the bubble levels and go. Don't forget to raise the beam after you unload.
It's critical to keep both headlight beams' cutoff below the line at the bulbs' height from the pavement. Check this on level pavement."
Jim A
66 Bronco QS 10w-30
Re: DIY Headlight aiming - Some Aiming Specs. [Re: Jim 5] #766149 11/12/06 12:41 AM
G-MAN Offline
Those instructions are clearly for ECE (E-code) headlights. Except for HIDs, the typical US beam pattern has no distinct cutoff, nor does it have the right hand flare up (for illuminating signs and pedestrians along the side of the road).
2007 Mercedes ML350 (Mobil 1 0w40)
2019 Camaro 1LT 3.6 (RLI 5w40 HD Low Ash)
Re: DIY Headlight aiming - Some Aiming Specs. [Re: G-MAN] #766150 12/03/06 12:26 AM
Dominic Offline
I found it really cool that my dad's new VW Jetta TDI came with E-code headlamps... the beam pattern is awesome on them.
2014 Mazda 6 GT - M1 EP 0W-20 with OE Filter
2018 Mazda CX-5 - M1 EP 0W-20 with OE Filter
Re: DIY Headlight aiming - Some Aiming Specs. [Re: Dominic] #766151 12/05/06 07:37 PM
B
brianl703 Offline
B
I'm pretty sure my Saab 93 has E-code headlamps It definitely has the beam cutoff with the rise towards the right for signs and pedestrians. Oh, it doesn't have HIDs either.
Re: DIY Headlight aiming - Some Aiming Specs. [Re: brianl703] #766152 01/10/07 11:29 PM
R
RFIRE Offline
R
There can be some overlap between modern SAE and E-code headlights, but a pure E-code headlight is not legal for install at the factory. They contain a city light usually, for which there is no SAE spec., and they lack amber reflectors and side lights.
Richard.
Re: DIY Headlight aiming - Some Aiming Specs. [Re: RFIRE] #766153 01/11/07 12:05 AM
M
moribundman Offline
M
it is very easy to determine what kind light the car has. Look for E and DOT markings on the lens(cover). Most foreign cars have e-code/DOT hybrids, with some producing nearly the same pattern as a e-code light -- the exception being reach of the left headlamp, which with hybrid lights is shorter than with e-codes.
My Audi has a two part headlight assembly. The headlights themselves are real e-codes (the parking light, "city light" is a misnomer, has not been hooked up), the blinker/marker/reflector assembly is DOT-compliant. Some US states (Washington and Orgeon, for example), allow e-codes.
Re: DIY Headlight aiming - Some Aiming Specs. [Re: moribundman] #766154 01/11/07 12:31 AM
B
brianl703 Offline
B
On my Saab 93 there are city lights (which come on with the parking lights), the side marker/parking light/amber reflector is not part of the headlight but is part of the "bumper strip". The "E-code" bumper strips have no parking light/reflector and a few people on Saabcentral have installed them.
Re: DIY Headlight aiming - Some Aiming Specs. [Re: brianl703] #766155 01/11/07 01:23 AM
M
moribundman Offline
M
I have a problem with the term "city light." The reason being, that it sounds like you may drive around the city with just them on -- which is illegal.
A European headlight has, besides low and high beam, the following modes (with the ignition off):
1. low beam switch on = both tail lights and both front parking lights (commonly a 5 Watt bulb in each low beam assembly) are on
2. set blinker left = left tail light and left front parking light on
3. set blinker right= right tail light and right front parking light on
Having the lights on only one side of the vehicle makes sense when parallel parked. No reason to waste battery juice on the curb side.
The use of the parking lights is not mandatory (use common sense). Driving with the parking light on is illegal, even during daylight.
Re: DIY Headlight aiming - Some Aiming Specs. [Re: moribundman] #766156 01/11/07 06:45 PM
B
brianl703 Offline
B
That apparently used to be legal in some cities (London?)
Mine does this.
Mine does not do this, I think it's probably a configurable setting with the Tech II scan tool.
I'm not so sure that usage of parking lights is illegal during the day, since some DRLs on some cars use the parking lights. US Federal regulations allowing DRLs overrode any state laws disallowing their use. My DRLs use the low-beam headlights AND the parking lights.
Re: DIY Headlight aiming - Some Aiming Specs. [Re: brianl703] #766157 01/11/07 08:37 PM
M
moribundman Offline
M
Brian, I was talking about Euro headlights and rules, not about about laws in the US.
Regarding London: I'd be surprised if their rules were to differ from other European countries, but then again, they are not part of continental Europe and they do drive on the wrong side to begin with.
Regarding point 2: My '96's DOT spec parking lights are both tail lights and yellow markers only in the front. The headlights do not use secondary low power bulbs. I suppose it varies?
Regarding point 3: that is a useful feature missing from US models. I doubt it can be reprogrammed. On my car the wiring itself is different.
Many DRLs use supplemental 21 Watt bulbs (Europe/Scandinavia), some use reduced voltage low beams (US/Canada).
Re: DIY Headlight aiming - Some Aiming Specs. [Re: moribundman] #766158 01/11/07 09:55 PM
B
brianl703 Offline
B
What are the rules regarding DRLs in Germany? I drove about 1800 miles in Germany with DRLs and nobody stopped me.
It used to be that way in London, apparently, but no longer.
Apparently so, I just checked again on the Saab and there is a low-power white light in the headlight assembly. The only other light that comes on in the front when the parking lights are on is the sidemarker.
On the Saab, a lot of things can be reprogrammed. Turning the DRLs off is just a matter of reprogramming and a dealership willing to do it. There are apparently settings based on the country the car is built for and the DRL off setting is "rest of world".
The DRLs on my Saab are low beams. There is no difference whatsoever in the vehicle lighting between DRLs and low-beam headlights. The only function the headlight switch has with DRLs turned on is to allow to you turn on the parking lights only (doesn't work with the key in the ON position--the DRLs still come on!) and to control whether pulling the turn signal stalk flashes the high beams or makes them stay on. (That's a bit of an annoying feature--I would much prefer the push to make the high beams stay on and the pull to flash them).
Re: DIY Headlight aiming - Some Aiming Specs. [Re: brianl703] #766159 01/11/07 10:23 PM
M
moribundman Offline
M
DRLs (Tagesfahrlicht) is available and legal in Germany and will probably become mandatory.
Sidemarkers (Begrenzungsleuchten) are legal on German vehicles (front only), but they must be white on cars and yellow on trucks.
Odd that DLRs on the Saab are running on full power. That wastes a lot of fuel.
Page 1 of 3 1 2 3
