My first oil analysis in this car. About a 50/50 blend of city and highway driving, approximately 300 miles per week. The car was at the dealership getting some warranty work done which resulted in multiple starts, so that is probably to blame for the fuel dilution and low flashpoint. I normally shift around 3,000 rpms until the car is fully warmed up with occasional spirited driving after that. Thoughts?
Blackstone Labs
Oil Brand/Weight : Castrol Syntec 0W-30 (GC Green)
Type of equipment : 2006 Volvo S40 T5 AWD (2.5l 5 cylinder turbo
Miles on oil : +/- 5,000
Total miles on vehicle : 15,200
Results ppm/% (this sample/universal averages)
Aliminum 2/3
Chromium 0/1
Iron 6/13
Copper 4/8
Lead 1/9
Tin 0/0
Molybdenum 23/55
Nickel 0/0
Manganese 3/1
Silver 0/0
Titanium 0/0
Potassium 3/1
Boron 0/41
Silicon 7/7
Sodium 2/4
Calcium 2907/1961
Magnesium 0/272
Phosphorus 791/768
Zinc 929/886
Barium 0/0
Viscosity at 210F 61.9
Flashpoint 350
Fuel 0.8
Antifreeze 0.0
Water 0.0
Insolubles 0.2
Blackstone's comments:
Your Volvo is wearing well at 15,200 miles and is apparently past break-in here in the first sample. We did find some fuel, present at 0.8%, but it's likely from the city driving you mentioned and it hasn't affected wear, though we'll keep an eye on it next time. Universal averages are based on an oil run of 5,500 miles. Your oil run was just short of this and wear looks much better and in the proper balance to indicate normally wearing parts inside your engine. The TBN read 2.8, showing some active additive left. 1.0 is low. Try 6,000-7,000 miles next time.
Blackstone Labs
Aliminum 2/3
Chromium 0/1
Iron 6/13
Copper 4/8
Lead 1/9
Tin 0/0
Molybdenum 23/55
Nickel 0/0
Manganese 3/1
Silver 0/0
Titanium 0/0
Potassium 3/1
Boron 0/41
Silicon 7/7
Sodium 2/4
Calcium 2907/1961
Magnesium 0/272
Phosphorus 791/768
Zinc 929/886
Barium 0/0
Flashpoint 350
Fuel 0.8
Antifreeze 0.0
Water 0.0
Insolubles 0.2
