Here are my statements regarding the definition of VI index number, and as all you veteran Bitoger’s are aware, I claim no professional expertise – I’m just an enthusiast!
Per the definition of Viscosity Index in the BobisTheOilGuy glossary, VI index “reflects the viscosity/temperature relationship between temperatures of 40 C and 100 C.”
It is the slope of the viscosity/temperature graph line between 40 C and 100 C.
The VI index number, for a base oil, is used as a basic yardstick to label conventional/mineral base oils as Grp I, II, II+, or Grp III.. (Note that levels of aromatics and saturates also separate the categories.)
VI index is also a common number listed on a motor oil product data sheet. It reflects the viscosity of the finished formulation, which includes additives and carrier oils, fluid additives, and, of course, the VI improver additive.
Q What is the VI index number on a product data sheet used for?
-A It provides an indication of the rate of viscosity change as the oil gets thicker while it cools down from 100C to the cold temp xW rating.
Straight weight SAE 30’s are typically about 105 VI index and get thick relatively quickly as the oil cools down. 0W-30’s or 5W-40’s can be 175 VI index and do not get thick as fast as an SAE 30 as temps cool down.
Q Does the VI index number indicate the amount of VI improver in the formulation?
A Yes and No, the VI index of a finished oil reflects the blended viscosity of pour point depressants, base oils, fluid synthetic additives, additives + carrier oils and VI improvers.
Q What is the significance of comparing the VI index of brand X & brand Y motor oils?
A Within the same grade, 5W-30 for example, a 151 VI versus a 156 VI simply indicates that the 156 has a slightly higher spread between the low end 5W rating and the 100C hot end.
Here’s a good GF-4/SM product data sheet example to consider:
Chevron Supreme 10W-30….10.8 cSt….5800 cP @ -25C….135 VI index
Phillips Trop Artic 10W-30…10.9 cSt….3500 cP @ -25C….157 VI index
Note that both oils are a very similar viscosity at the hot end and the VI difference is due to the better cold temp properties of the Trop Artic 10W-30.
Now go ahead & fire away with your comments!
