I flushed out my cooling system today. During this process, I removed the lower radiator hose from the radiator and the thermostat housing.
When I looked inside, there was some white stuff on the inside of the hose that went away when I put water on it and appeared when the water dried up. What is this white stuff in the hose? Is it mineral deposit or stuff from aging rubber?
Since it is one of my radiator hose, should I believe that stuff is inside the rest of the cooling system also? If so, is it possible to clean this stuff out?
I don't recall seeing white stuff lookng through the fill hole on my radiator.
