Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
SAE 20 non-detergent oil
by fleetwood62. 03/21/19 10:39 AM
PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Honda st1300 LED light
by Zuraxus. 03/21/19 08:26 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
114 registered members (1leater, 2K2AcuraTL, aircooled, ammolab, 240_Ed, 13 invisible), 2,038 guests, and 180 spiders.
Topics286,196
Posts4,903,982
Members67,576
Most Online2,967
Mar 10th, 2019
dexron III instead of dexron VI..*gulp* #739669
10/03/06 07:07 AM
10/03/06 07:07 AM
eastern high sierras
spongebob Offline OP
parts guy at the dealer sold me 8 quarts of dexronIII said this is waht they use in the shop..after dumping the atf into the tranny and fireing it up, i noticed the dip stick says dexron VI on it...now what?
my truck is a 06 duramax with a 6 speed allison auto transmission...
Re: dexron III instead of dexron VI..*gulp* [Re: spongebob] #739670
10/03/06 07:25 AM
10/03/06 07:25 AM
MO
obbop Offline
obbop  Offline
MO
Go to the service department, show them the stick of dip, tell them what THEIR supposedly trained seller of parts said, then firmly ask them to do what they know needs done.
If step one doesn't work, come back here.
National Master-at-Arms
Student Revolutionary Strike Force
Re: dexron III instead of dexron VI..*gulp* [Re: obbop] #739671
10/03/06 08:31 AM
10/03/06 08:31 AM
SC
G-MAN Offline
G-MAN  Offline
SC
You need to get the correct fluid, Dex VI, flush all the Dex III out, and put the Dex VI in.
This transmission was not designed to operate correctly on Dex III.
2015 Lexus IS250 (Pennzoil Platinum 0w20)
2007 Jeep Grand Cherokee (Mobil 1 HM 5w20)
2005 Corvette (RLI 5w40 HD Low Ash)
Re: dexron III instead of dexron VI..*gulp* [Re: G-MAN] #739672
10/03/06 05:58 PM
10/03/06 05:58 PM
Indiana
nascarnation Offline
Indiana
Actually your Allison will run fine on Dex III.
http://www.allisontransmission.com/service/faq/index.jsp?CategoryID=11#98
I was designed and developed with Dex III and none of the 2006 changes require Dex VI, which was primarily developed for the new Hydramatic 6 speeds. TranSynd will be even better and should be a lifetime fill in your pickup.
Re: dexron III instead of dexron VI..*gulp* [Re: nascarnation] #739673
10/03/06 06:34 PM
10/03/06 06:34 PM
The Motor City
Kestas Offline
Global Moderator
Kestas  Offline
Global Moderator
The Motor City
Assuming it'll run fine on Dex III, keep in mind that the main difference between the two fluids is that the useful life of Dex III is half that of Dex VI.
Re: dexron III instead of dexron VI..*gulp* [Re: Kestas] #739674
10/03/06 07:00 PM
10/03/06 07:00 PM
SC
G-MAN Offline
G-MAN  Offline
SC
My mistake. I was thinking he had the new 6 speed that requires Dex VI. He needs to make sure he doesn't before continuing to use Dex III.
Actually, the biggest difference between Dex III and Dex VI is the viscosity. Dex VI is a much thinner ATF.
Re: dexron III instead of dexron VI..*gulp* [Re: G-MAN] #739675
10/03/06 11:34 PM
10/03/06 11:34 PM
The Motor City
Kestas Offline
Global Moderator
Kestas  Offline
Global Moderator
The Motor City
From older discussion, I was under the impression that Dex VI was only a little thinner, not much thinner.
Re: dexron III instead of dexron VI..*gulp* [Re: Kestas] #739676
10/04/06 12:22 AM
10/04/06 12:22 AM
Southern California
Ray H Offline
Ray H  Offline
Southern California
I'd bet the D-III will be fine for 15,000-20,000 miles at which point, drain it and replace it with D-VI. Think of this episode as an "extended flush"...
Re: dexron III instead of dexron VI..*gulp* [Re: Kestas] #739677
10/04/06 12:46 AM
10/04/06 12:46 AM
SC
G-MAN Offline
G-MAN  Offline
SC
Around 7.0 cap for Dex VI, if I remember correctly. I think Dex III is capped at around 8.5.
Re: dexron III instead of dexron VI..*gulp* [Re: G-MAN] #739678
10/04/06 01:22 AM
10/04/06 01:22 AM
RI
unDummy Offline
unDummy  Offline
RI
Its an Allison, use a TES-295 ATF.
If the vehicle isn't worked, the DexronIII will work fine. I just don't see it as a fluid for extended usage. Throw in a bottle of lubegard red, run it for 10k miles, then switch back to DexronVI or a full synthetic Dexron III.
Those who say it cannot be done, should not interrupt the person doing it.
Your automaker lied!
Is this a spelling/grammar forum or BITOG?
Re: dexron III instead of dexron VI..*gulp* [Re: unDummy] #739679
10/04/06 09:46 AM
10/04/06 09:46 AM
CA
The Critic Offline
The Critic  Offline
CA
Dex VI is capped in the mid 6 range, but the Petro-Canada Dex VI product is 6.0cst @ 100C. Most Dex IIIH fluids are 7.5.
While the fluid may be OK for the transmission in terms of protection, GM may have changed some programming of the transmission software to accommodate the Dex VI fluid. For instance, since Dex VI flows much better (and is much thinner) at low temps compared to Dex IIIH, the transmission may behave strangely if operated under extremely cold conditions.
2011 Toyota Prius 1.8L - 185K - SuperTech Dexos Full Syn 0W-20
2007 Honda Accord 2.4 - 135K - Mobil 1 EP HM 5W-30
Re: dexron III instead of dexron VI..*gulp* [Re: The Critic] #739680
10/04/06 10:07 AM
10/04/06 10:07 AM
SC
G-MAN Offline
G-MAN  Offline
SC
I've got just one thing to say to you:
Re: dexron III instead of dexron VI..*gulp* [Re: G-MAN] #739681
10/05/06 01:27 AM
10/05/06 01:27 AM
MI, USA
Whitewolf Offline
Whitewolf  Offline
MI, USA
The DEXRON-VI fluid is thnner when it's new (6.0cSt at 100C as you said) however the DEXRON-III fluids are typically not shear stable so the viscosity drops rapidly from about 7.5 cSt at 100C when new to about 5.0 cst in just a few thousand miles. In the end they can go as low as 4.0 cst.
The viscosity difference is the most visible feature of DEXRON-VI vs DEXRON-III but it isn't the biggest difference. The biggest differences are in thermal stability and friction durability (compare the specs and you will see.
My definition of an expert in any field is a person who knows enough about what's really going on to be scared.
~ PJ Plauger
Re: dexron III instead of dexron VI..*gulp* [Re: spongebob] #4647966
01/27/18 01:00 PM
01/27/18 01:00 PM
FL
Nolefan Offline
Nolefan  Offline
FL
This is what it says on Wikipedia.
This says that the thinner Dexron VI is better than the min shear viscosity of 4.2. it also says that it maintains viscosity better Than Dexron 3.
As for Amsoil ATF specs
Even the Amsoil OEM version of their ATF thin is 5.8, still better than the min requirement of 4.2
Amsoil has warranty secure for their products. They stand behind it even when it's still under manufacturer warranty.
Believe it. I am not an Amsoil Dealer, but I have studied data and third party test about them. They appear to be as good as their claims. Also, Amsoil has longer life than most other brands.
Re: dexron III instead of dexron VI..*gulp* [Re: spongebob] #4648178
01/27/18 05:42 PM
01/27/18 05:42 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
Amsoil's ATL is imply their LV version of the 6.X cSt ATF comparable to Dexron VI.
See
Dexron VI Improvements
and Whitewolf's quote above (he helped develop it):
"I can't change the direction of the wind, but I can adjust my sails to always reach my destination." Jimmy Dean
