I havent started my wrx for about 4 months now, and I probably wont be ready to fire it up for at least two more months. The oil in the car is Rotella T Synth 5w40, + 5oz SX-UP, and a oversize baldwin oil filter. Theres only 1k miles on the oil.
My plan was to crank the engine for 10 second intervals with no spark and fuel until my pressure gauge is reading some pressure, then start it. I will probably also put some drygas or something like that in the gas, although there is already FP in it now.
Car has 80K on it and engine has perfect compression.
Right now the battery is disconnected. Is there anything else you guys recommend I do while the car is sitting?
Should I change the oil and/or filter before I start it?
