Does anyone have second citizenship?
by Martula - 11/14/19 10:38 PM
2019 i30 Nline 1.6T and first service (1500km)
by rov137 - 11/14/19 10:11 PM
Garbage Disposal Replacement
by bunnspecial - 11/14/19 09:58 PM
Nest thermostat
by miden851 - 11/14/19 09:06 PM
2011 G37X
by maverickfhs - 11/14/19 08:27 PM
Recommendations for oil filter
by dawgn86 - 11/14/19 07:38 PM
2001 Subaru Outback $2,300 OBO
by 14Accent - 11/14/19 07:16 PM
Brake Friction Code List
by 92saturnsl2 - 11/14/19 07:14 PM
Accord reached a milestone today!
by mclasser - 11/14/19 06:59 PM
Is an alignment absolutely needed after new tires?
by SouthDakotaDad - 11/14/19 06:11 PM
Redline Professional Series 5w20
by burla - 11/14/19 06:00 PM
Backup Camera
by George7941 - 11/14/19 05:26 PM
'11 Prius 15k OCI Amsoil 0W-20
by mdv - 11/14/19 05:16 PM
Lightweight easy up
by Redright9 - 11/14/19 05:00 PM
Thinking of getting a cat
by 53' Stude - 11/14/19 04:42 PM
Apple Watch users
by madRiver - 11/14/19 03:05 PM
It's here, arrived early still 1 week to wait
by BeerCan - 11/14/19 02:20 PM
Cooling leaks at hose to housing connections
by Fitz98 - 11/14/19 12:53 PM
rov137, Dorisy, DesktopDave, HPD, kildeth
69868 Registered Users
67 registered members (AtlasFBG2, 77GrandPrix, austinlunsford, aquariuscsm, 14Accent, 6 invisible), 1,448 guests, and 39 spiders.
Topics297,431
Posts5,115,455
Members69,868
Most Online3,589
Nov 2nd, 2019
oxiclean as a bore cleaner #620962 10/27/04 06:27 AM
J
jhnrckr Offline OP
J
I just spoke with a guy who makes some seriously high end trap guns and asked him what he used to clean his bores. He recomended oxiclean solution poured in the barrel and plugged with a finger. I guess a couple of shakes is all it takes to completely clean it plastic fouling and all. As long as it is dried and oiled I can't see any risk in this. His guns cost more than most cars and he has not had a problem. I think I am going to try it next time my barrel is dirty. If anyone beats me to it, please post results.
Re: oxiclean as a bore cleaner #620963 11/03/04 04:50 AM
G
Gregory Offline
G
I know Oxi blackens AL. dont know about other metals.
Re: oxiclean as a bore cleaner #620964 11/03/04 12:23 PM
Chris B. Offline
This is the biggest load of crap I've heard all day! No offence.
I have tried just about everything to clean guns and some work very well but this just does not make sence. It would be very abrasive and could rust almost right away against a non-lined bore.
This reminds me of the mechanic that "knows" about oil and says Valvoline is the absolute best oil. Granted he is a very good mechanic but really knows nothing about Triboligy.
Same thing here. Probibly an excellent gun maker but never really studied the chemicals needed to remove metal folwing and propellent fowling.
Re: oxiclean as a bore cleaner #620965 11/06/04 11:27 PM
J
jhnrckr Offline OP
J
Despite your advice I went ahead and tried it and it works pretty good. Much better to work with than smelly solvents.
Re: oxiclean as a bore cleaner #620966 11/06/04 11:47 PM
tom slick Offline
oxyclen is non-clorine bleach that you mix with water. if running water and bleach through your gun is acceptable then give it a try (i don't have the knowledge determine that). the powder completely dissolves in water so i don't think abrasiveness would be an issue.
Re: oxiclean as a bore cleaner #620967 11/12/04 11:49 PM
1
1sttruck Offline
1
As I recall black powder shooters often use soap and water to scrub their weapons as soon as possible after shooting, and with the good ole corrosive primers (they did have excellent storage life) some people started with stuff like seltzer water, soap and water, etc., and then followed up bore cleaner.
A simple test is to use a cleaner, and then follow-up with another cleaner; if it's clean either the first cleaned well or the second one isn't any better than the first.
Re: oxiclean as a bore cleaner #620968 11/13/04 05:29 AM
Chris B. Offline
You would think the extra "oxygen" would make the steel rust faster.
Maybe I'll try it on one of my "junk" guns just to see.
Re: oxiclean as a bore cleaner #620969 11/20/04 04:42 AM
J
JohnBrowning Offline
J
I do not know about the Oxi-Clean. I have no problem with the water. Many old timers clean their guns with boiling hot soapy water. After they do this they have to clean and lube everthing!! I have never tried the boil the hot water as a rountine cleaner. It is an excellent way to remove all the cosmoline off of old rifles.
Re: oxiclean as a bore cleaner #620970 11/20/04 11:32 AM
J
Jakebrake Offline
J
quote:
With black powder weapons soap and water is a good cleaning agent. Petroleum based cleaners are not used because any petroleum residue would contaminate a black powder charge if the gun were to be loaded for a period of time. Petroleum residues would not have this effect on guns that fire metallic cartridges.
On shotguns with screw-in choke tubes I would be very carefull to get the water/oxyclean out of the threads. If the gun was a gas operated autoloader I would also be certain that the gas ports/piston are also dried and lubricated.
All the gun cleaners that I have used are very good at removing powder/wad fouling and I would stick with them...leave the oxyclean for the laundry.
