Instead of disconnecting / reconnecting several times to flush, just remove your bottom hose once, let the radiator and block drain, and re-connect. Ready your garden hose. Disconnect the top hose and crank the engine. When the thermostat opens, the old stuff will start pouring out the top hose. Turn on the garden hose and stick it in the top of the radiator and let the system flush itself for a while. When the water runs clear out the top hose, turn off the garden hose and let the pump drain the radiator. Start pouring your 50/50 mix into the radiator until you start to see green coming out the top hose. Reconnect the top hose to the radiator, top off the radiator, cap it and fill the reservior. Take it for a drive, allowing the system to draw from the reservior and check the level when you return home.
