picked up a gallon of pre-diluted Honda coolant. the bottle says "Type 2" coolant. is there a Type 1? if so, what's the difference. right now the car has blue coolant in it. is Type 2 the right stuff?
thanks.
thanks.
Ray,quote:
$16.00 for what amounts to two quarts of antifreeze and 35 cents* worth of distilled water
why?quote:
Originally posted by ChrisW:
hmm...i would trust G 05 chemistry moreso than honda coolant any day in my civic or newer honda.
Most if not all the import brands advise using distilled or de-ionized water to dilute. Honda's definitely among them. It would be totally out of character for the company to use nothing more than filtered tap water into the mix for their pre-diluted coolant. Since the Japanese antifreeze formulations already are dosed with phosphate for additional corrosion and cavitation protection, throwing additional mineral content into the mix would only encourage unwanted mineral precipitate fallout in use, which in itself may answer the question why Honda Type 2 Coolant is only available as pre-mix - to assure that owners won't inadvertently dump tap water of unknown hardness into their cooling systems? (or worse, diluting with sodium-laden residential softened water)quote:
Originally posted by LT4 Vette:
...Are you sure they don't just use city tap water when they make the pre-diluted Honda coolant ??...
I called Manchester Honda in CT. They won't ship it, but they have Honda concentrate for $14 a gallon. Parts guy didn't know if it was Type I or II...quote:
Originally posted by Chris Meutsch:
I called two local Honda dealerships today asking about concentrate. They don't make it and want $12 per gallon.
