Prestone DEX-COOL* will be fine in a Toyota, Nissan, or Honda, regardless whether those OEMs approve or not**. 2-EHA is NOT a plasticizer. (Another urban legend promulgated by a poorly researched "trade" publication quoted by Zerex on their website and accepted as fact by forumners too lazy to bother researching the available online documentation. I DID bother several months ago.) 2-EHA is an organic acid that is used as a food preservative, corrosion inhibitor, in making pharmaceuticals, plastics, and, combined chemically with other substances, can also be used in MAKING plasticizers. In bulk, 2-EHA is routinely
shipped in plastic containers. (Hydrogen, a component of water, can be used to make nuclear bombs, but no one seems to be unduly worried about their
Aqua Fina exploding.) Other organic acids used as corrsion inhibitors, such as Sodium Benzoate (used as the organic acid technology corrosion inhibitor in G-05) can also be used in MAKING plasticizers. (
*If you buy the current yellow jug Prestone antifreeze/coolant that's labled as an extended life product, it differs from the GM approved & licensed Prestone DEX-COOL only in the color of the dye used (green) and priced correspondingly less since there's no licensing fee Prestone has to pass on to use the GM trademark, "DEX-COOL".
**However, if your rice burner is still under factory warranty, better stick to the grossly overpriced OEM juice to avoid possible warranty claim issues.
[ March 31, 2005, 06:06 PM: Message edited by: Ray H ]
