Well, I looked up into the tiiiiny little drain hole on the radiator on this last flush, and the white stuff appears to be inside the radiator. Appears to be caked on, and not coming off with just water flushes (prob the stuff I'm seeing is floating around in the system); it seems the prestone cleaner did not get this stuff off. When I use the drain plug for the engine block, none of this white stuff appears in the drain water as it does from the radiator.
Radiator drains about 1.5 gallons and the engine block about 1 gallon, leaving about 1/2 gallon in the heater core and the rest of the engine, about 12.3 total. (I will account for this when filling with G 05).
When this stuff builds on the inside of the radiator, does this mean a improper coolant ratio on the previous fill?
I'm afraid the G 05 will clean this white stuff off the radiator core with time of and make the new coolant rather useless.
Well, if it comes to it, I will do another drain within the next six to twelve months, take out the radiator, and take it to a radiator shop here in town to get preofesionally cleaned.
BTW, the previa uses a remote pressure/overflow tank, so the radiator has no "cap" so to speak.
