I have a JD diesel tractor that's had the factory coolant left in for 9 yrs. (it's also had very little use over that timeframe)
There are no problems with the cooling system but I'm planning to do a flush and refill.
Should I chemically clean the system?
If so, which cleaners work best. I see that the common cleaners are either:
1. Prestone Heavy Duty - Oxalyic acid with a seperate neutralizer
2. Prestone Super Radiator Cleaner - Sodium Citrate is the active ingrediant
3. Prestone Fast Flush - Looks like TSP is the primary active ingrediant
Which would you choose and why?
