to the original thread, and to correct some misinformation that was stated: DO NOT use high-silicate coolant in a diesel. Is your '85 truck a diesel?
Older diesels like the 80's and early 90's Ford 6.9/7.3L IDI (indirect injection) and powerstroke (direct injection) diesels were most prone to cavitation. The definition of cavitation was well described above. This was combatted with an SCA- supplemental coolant additive. A google search on SCA will give good info on coolant in general. The SCA for Ford/Navistar was a combination of nitrite/molybdate by Fleetguard, with the molybdate more intended for cavitation protection. Nitrite I think is more for pH control, but don't quote me on that. Problem with adding this formula of SCA is that it had to go into low-silicate ethylene glycol (green antifreeze) at somewhat precise amounts otherwise it would make the silicate precipitate out of the glycol solution and form the green goo that was mentioned. For this SCA, you need a antifreeze that meets ASTM-4985 (I have it committed to memory). Another reason, if not mentioned, was you shouldn't exceed 70% of ethylene glycol to water mixture, otherwise as the ethylene glycol ages in the motor/radiator it will tend to drop out the silicate and form green goo and clog the cooling system.
From what I've learned, silicate is for aluminum protection/corrosion control and works by plating effect. But silicate has the drawback I mentioned, plus it is also inherently abrasive. This is one of the main reasons for the trend away from traditional green silicated ethylene glycol to the extended-life OAT (organic-acid tech) antifreezes, not to mention they have short service lives. If you are looking for low/no silicate ethylene glycol (green antifreeze) be cautious to what you pick up. If it says low-silicate but does not say "meets ASTM-4985", then it is not low silicate. Prestone in the yellow bottle is the biggest offender- it is by no means low silicate.
As for dexcool- there's a big myth (sort of) that dexcool is terrible because it sludges up. This story is part true and the way I heard it, came about when a good number of S-10 pickups left Chevy with coolant systems not completely/properly filled. They had air in them, and the dexcool after time would form brown clumps and result in cooling system failure. So in this case, putting the blame on dexcool would be like blaming some motor oil for engine failure when you only had 2 qts of oil in the engine when it calls for 5 (sorry, best analogy I can come up with). Point is, no cooling system should have air in it otherwise bad things are guaranteed to happen.
... '89 Ford F250 7.3L IDI diesel owner
some useful links:
http://www.imcool.com/articles/antifreeze-coolant/SCA-Part1.htm
http://www.intellidog.com/dieselmann/home.html
http://www.penray.com/coolingtechfacts/
http://www.dieselstop.com
http://www.amalgatech.com/technical/Index.htm
[ February 10, 2004, 02:25 PM: Message edited by: 1 FMF ]
