Getting back to the original poster's question, I took a few moments to research the Toyota juice. The back of the Toyota jugs lists four primary ingredients and their CAS numbers:
ethylene glycol (CAS#: 107-21-1)
diethylene glycol (CAS#: 111-46-6)
organic acid salt (CAS#: 532-32-1)
hydrated inorganic salt (CAS#: 1310-58-3)
Virtually all antifreeze/coolant products in general use, except those based on propylene glycol "environmentally friendly" products use the two listed glycols. I suspect the second is an unavoidable byproduct of the synthesis procedure, but someone with more chemistry behind him than I have would be able to verify or dismiss that speculation. The two listed salts caught my attention though. I plugged the CAS numbers into my browser and got immediate hits. The "organic acid salt" in the Toyota juice is sodium benzoate. This is clearly the organic acid salt corrosion inhibitor, and obviously differs from the two that Prestone chose for its particular DEX-COOL flavor. The "hydrated inorganic salt" is potassium hydroxide. I suspect, but can't verify, that the potassium hydroxide is used as a pH buffer. (again, someone with more chemistry training would be welcome to chime in) In any event, there's reason to believe that the Toyota antifreeze/coolant is really an OAT-type, devoid of silicates and phosphates (or very nearly so), and though not identical to any of the licensed DEX-COOLs, is close enough in principle that Toyotas would run just dandy on Prestone DEX-COOL, and quite probably, a HOAT formula such as Zerex G-05. About the only thing I wouldn't trust to a recent Toyota that came factory filled with cherry soda-pop coolant would be silicate and phosphate-laden conventional Prestone. By the way, the new -cheap- SuperTech extended life antifreeze/coolant at Wally*World lists the same ingredients as Prestone's licensed DEX-COOL, much of the same descriptive text on the back of the jug, but without the licensed DEX-COOL imprimatur from GM. In another thread someone stated that the extended life SuperTech juice is dyed green, not orange. (more "rainbow confusion" for car owners, pump jockeys, and some independent radiator shop owners)
