Whoops Robbie, I missed the other comments yesterday, so here goes: No scanner, this is film negatives, but Photoworks (formerly Seattle Flim Works puts them on the computer for me). I am doing blotters like a madman--about 8 in 1800 miles. Wife thinks I am crazy. Maybe so, but it fits in with "WATCH, WATCH, WATCH." Yeah I also write the miles on the card with a key card telling what oil (or mixture) I used.
After changing out the 1800-mile oil and filter that had the closing in black ring, I ran it five minutes and did a blotter. Amazing, there is a distinct but faint ring.
Guess I should mention the 1800-mile oil started as 5w30 Maxlife then, to improve oil pressure (36 psi hot at 2000) I drained off 2 qts and added 2 qts 20w50 Maxlife to simulate a 10w40 and got 43 psi, then added several ounces of Maxlife Engine Protector, followed by a 15 oz Rislone (trying to use up left over stock), and at 1000 miles I freshened up with a quart of 10w40 Maxlife, but later topped up with 1/3 qt Royal Purple 10w40. But I have since repented
and have nothing but Maxlife 10w40 in it now.
Virgin Maxlife blot is very large and light, but can be seen without holding up to the light. That brings up a point. It would be good to have control over (or consistency with) the amount of oil placed on the card as then blot size would be more meaningful.
"Should take longer..." Yeah, I think this engine has had a poor service life before I got it and the Durablend apparently is not the best for cleaning an engine.
"Mine usually just slightly darkens all over
and keeps darkening," That is the case with the Aerostar on Durablend. "then the fall-out later on, a little here and there" Will keep an eye out for that.
"this ring you can see through? kinda like a light cloud?" I can see through the middle, it is grey, but the ring is dark and thin and then the oil is tan to brownish outside the ring.
Then there is the motorhome's 460 V8 in which I must have cooked the polymers in its Durablend when it idled for over an hour last July in 90s temps. Water temp gauge was at upper end of NORMAL zone. When I drained that oil it looked pretty bad. Now it has Maxlife and the black ring is there already at 250 miles.
Thanks again. Paul
[ December 26, 2003, 01:22 AM: Message edited by: TallPaul ]
