Ok just bear with me,
Last night I was reading over at the lube control site in the lab reports section.
Not only did I find some very useful things of how LC can be used but how you can make penetrating oil with it. It also says that the rust an corrosion will drip away and the threads on the nut and bolt will look like new with protection left behind.
The site says it can be mixed by volume to 70% DexronIII synthetic ATF to 30% LC.
Ok here's the gameplan for me, so please tell me if this is a good idea or not or if I'm just plain stupid......
I have about 1 gallon left of Amsoil ATF, my truck needing a good strong Fuel System cleaner that it does, I was thinking sometime in the not too distant future get a gallon of both LC and FP.
Use LC and my tranny fluid to mix the solution, would this work?? I know some of you are probably laughing with your heads falled back but I'm just brainstorming,,,,AR
