2015 Silverado Trany Pan drop
by Realtech214
03/29/17 09:34 PM
Transfer Case Lube Substitution?
by TheLoneRanger
03/29/17 09:32 PM
Taking a day trip to New Orleans...what to do?
by gregk24
03/29/17 09:30 PM
Motorcraft FL500S filter cut open
by AccF150
03/29/17 09:16 PM
What car wash to use before clay bar?
by DreamerGT
03/29/17 08:15 PM
Any love for E-mowers/lawn equipment?
by salcuta88
03/29/17 08:14 PM
Takata Airbag Recall..."Loaner car" Conundrum
by SumpChump
03/29/17 08:09 PM
Incorrect Lifter Clearance - Vacuum issues?
by Spetz
03/29/17 07:41 PM
looking for a dealership decal...
by earlyre
03/29/17 07:23 PM
Kalifornya gas tax
by 04SE
03/29/17 06:51 PM
How does a 2-step pressure relief oil pump work?
by GravelRoad
03/29/17 06:46 PM
Looking at Used 2015 Fusion / Need pricing advice
by Greggy_D
03/29/17 04:56 PM
ceramic brake pads
by marine65
03/29/17 04:47 PM
The difference between a scientist and a teamster?
by Ausfahrt
03/29/17 04:31 PM
rear driveline center spline
by mjoekingz28
03/29/17 04:27 PM
Fusion Locked Out!
by wolfehunter
03/29/17 04:25 PM
Discussion about viscosity
by FowVay
03/29/17 04:18 PM
Clearance oils still at Autozone.
by car51
03/29/17 04:17 PM
Detroit/Windsor tunnel
by Papa Bear
03/29/17 04:14 PM
Carquest Red oil filter... just about cried.
by mrsilv04
03/29/17 03:52 PM
starshockey, Jarredm, KovMan, John300ZX, MariaKaras
61021 Registered Users
90 registered (70fastback, 67lemans, 69GTX, 2002 Maxima SE, 4ever4d, 2015_PSD, 15 invisible), 2178 Guests and 9 Spiders online.
61021 Members
66 Forums
263003 Topics
#586492 - 07/25/03 07:05 AM Any opinions??
Mike Piles Offline
Loc: Arnold, MO
Done by OilGuard
Oil: Caterpillar 5W40 SDEO
Miles on oil 10166
Miles on Car 91766
Aluminum 4
Chromium 4
Copper 8
Iron 23
Lead 0
Tin 1
Silicon 9
Potassium 0
Sodium 0
Water <0.1
Oxidation 64.4
[email protected] 17.0
Glycol None Detected
TBN 3.4
Soot 0.8
Notation.
All engine wear rated appear normal. High degree of oxidation Indicated. Suspect high operating temperature and/or over extended drain interval.
Any opinions would be appreciated.
Thanks
Mike Piles
Mike
00 Green VW Jetta 5 speed TDI
#586493 - 07/25/03 09:18 AM Re: Any opinions??
TooSlick Offline
Loc: Dixie
Mike,
I think you need to thoroughly clean your EGR valve. I believe what is happening here is the valve is stuck open with oil/soot deposits. This is allowing lots of exhaust loaded with oxides of sulphur and nitrogen into the combustion chamber and generating very high levels of nitration/oxidation. Both these processes result in the formation of organic acids, which is depleting the TBN. In addition, oxidation essentially increases the molecular weight of the oil and is causing the thickening you see.
The wear rates look pretty good, but running with very high rates of oxidation will result in the gradual formation of sludge/varnish/carbon deposits. So this isn't something you want to let continue. It is very uncommon to see Delvac 1 degrade like this in the TDI ...!
TooSlick
