PCV valve average lifespan
by DrRoughneck
02/24/17 12:17 PM
'97 Volvo 850 - 50k on oil
by djmc
02/24/17 11:20 AM
phishing - html and redirect
by Donald
02/24/17 11:10 AM
Acura MDX Oil Consumption
by Brolly
02/24/17 11:09 AM
Thinking of buying this Cadet mower. Any thoughts?
by 2civics
02/24/17 10:34 AM
'16 Camaro SS diff fluid help
by stook2001
02/24/17 10:30 AM
Good Thing I Didn't Include The Back Label........
by AirgunSavant
02/24/17 10:30 AM
Wrong Oil in Crankcase
by JosephH1
02/24/17 10:19 AM
propane or diesel generator
by Donald
02/24/17 10:03 AM
Neighbors garbage cans
by Brybo86
02/24/17 10:02 AM
Lucas synthetic 75W-90 - Should I use it?
by ledslinger
02/24/17 09:39 AM
Shop that mainly uses Duralast parts
by mclasser
02/24/17 09:37 AM
Pulleys and Belts on a Riding Lawn Mower
by 2civics
02/24/17 09:18 AM
Waterless Anti-freeze
by Geoff1200
02/24/17 08:32 AM
Top Tier E0
by Duffyjr
02/24/17 08:16 AM
Where to source large bushings?
by Klutch9
02/24/17 07:53 AM
When did the US choose sulfur over sulphur ?
by Shannow
02/24/17 07:19 AM
Wind and solar power are disrupting electricity...
by wemay
02/24/17 05:53 AM
Tonneau cover options
by messedJ
02/24/17 01:38 AM
WHOA Recent Topics!!
by Brybo86
02/23/17 11:35 PM
Geoff1200, ggw1957, jujufly, phrancke, Mbrock
60622 Registered Users
83 registered (4WD, adrianp89, 69GTX, adriano, 87sammy, 6 invisible), 2216 Guests and 14 Spiders online.
60622 Members
66 Forums
261505 Topics
#586492 - 07/25/03 07:05 AM Any opinions??
Mike Piles Offline
Loc: Arnold, MO
Done by OilGuard
Oil: Caterpillar 5W40 SDEO
Miles on oil 10166
Miles on Car 91766
Aluminum 4
Chromium 4
Copper 8
Iron 23
Lead 0
Tin 1
Silicon 9
Potassium 0
Sodium 0
Water <0.1
Oxidation 64.4
[email protected] 17.0
Glycol None Detected
TBN 3.4
Soot 0.8
Notation.
All engine wear rated appear normal. High degree of oxidation Indicated. Suspect high operating temperature and/or over extended drain interval.
Any opinions would be appreciated.
Thanks
Mike Piles
Mike
00 Green VW Jetta 5 speed TDI
#586493 - 07/25/03 09:18 AM Re: Any opinions??
TooSlick Offline
Loc: Dixie
Mike,
I think you need to thoroughly clean your EGR valve. I believe what is happening here is the valve is stuck open with oil/soot deposits. This is allowing lots of exhaust loaded with oxides of sulphur and nitrogen into the combustion chamber and generating very high levels of nitration/oxidation. Both these processes result in the formation of organic acids, which is depleting the TBN. In addition, oxidation essentially increases the molecular weight of the oil and is causing the thickening you see.
The wear rates look pretty good, but running with very high rates of oxidation will result in the gradual formation of sludge/varnish/carbon deposits. So this isn't something you want to let continue. It is very uncommon to see Delvac 1 degrade like this in the TDI ...!
TooSlick
