I got the FelPro gasket last evening when I was in South Haven at the Auto Zone. BOY! What a gasket! Nice smooth rubber, stiff and yet adjustable enough to move around. It has smaller holes for the pan bolts so you can just put the bolts into the pan AND gasket and then put the pan back up on the car's transmission. On my new pan, I put in a drain plug that I got from Advanced Auto Parts. Cost me 1.98. It is a hollow bolt with outside and inside threads. On the one end is a smaller plug with gasket. The other end fits into the 1/2 inch hole you drill in the pan. There are 2 nylon gaskets. One goes on the outside of the pan and the other goes on the insides. You just snug them up good and tight, and don't have to do any welding.
I'm adding synthetic fluid Modil 1 ATF full synthetic. So, next month I can just drain out about 5 quarts and add another 5 quarts in there and help with the "dilution" over to synthetic rather than go though the draining of the torque converter method of pumping out the transmission though the cooling lines.
The Fel-Pro is a good high quality gasket, and being the property it is, looks to be re-usable.
Vern
