While I must say that no 2 CV boot supplier/manufacturer are created equal (material quality-wise), IMHO they should typically lasts an easy, comfortable 3~15 years typical.
Japanese cars mostly uses NTN boots which, IMHO, are far better in terms of polymer quality than, say, EMPI or some other aftermarket suppliers.
My B6 boots didn't require servicing for 13 straight years (or equiates to 155kkms), and it's NTN. On the flip side, my friend's US assembled Sentra boot failed every 4 yrs and replaced (twice already) using EMPI.
The 2 main factors that caused CV boots to deterioriate are (a) mineral oils in CV joint grease (b) heat.
If you don't believe me, try dabbing a new, fresh CV boot with the moly CV grease, leave it for 20 mins and then wipe it off and see what happens. You shall see a blotch left behind with localised swellings and that just shows you why/what's going on when CV boot polymerised material (rubber-like, but made by some other elastomers) comes into contact with oil-based chemicals.
The other factor to the longevity of a CV boot will be the service duty of your vehicle. E.g. if your vehicle does a lot of towing, heavy loads, etc. where it would generate a lot of heat, your CV boot will deterioriate sooner for the boot, with the joint assembly itself, has to find ways to dissipate the heat generated when the joint is in service. This heat will gradually deterioriates your boot over time.
