My 95 Grand Marquis has had this error code, P0401, for the last 6 years and I'm wondering if anyone has had this error and fixed it themselves. I found two solutions, replace the sensors or remove the elbow that attaches the throttle body to the intake and clean the EGR ports which tend to clog with carbon.
I attempted to remove the throttle body elbow, but due to space issues I could not pull it off to clean it, also I didn't have the correct gasket. The EGR valve itself is not faulty, I believe that the ports are clogged, and a friend believes the sensors are faulty. There is a website that I found which showed the ports and I see where they are located.
I was thinking of using some Amsoil Power Foam to clean it, by spraying it down the throttle body and letting it soak around the port openings. Perhaps that would help dissolve enough carbon, if they are clogged, to get a constant flow going and turn off the light.
Anyone got any better suggestions, or better instructions?
