dripping. Only does it when the engine is cold first thing in the morning.
The engine has all new hoses, including this one. It's dripping where it mounts to the lower radiator, I have very slightly tightened it up a bit - was told to be careful cause the mounting on the bottom of the radiator is plastic.
Thing is is I've tightened it just a tad over the last 2 mornings, thinking it's done dripping, but sure enough go to start it stone-cold this morning and it starts dripping again. However, after running for only 3-4 minutes it stops dripping automatically, so I can't ever decide if it's on tight enough or not.
Think the problem is is I'm afraid of breaking/bending the plastic mount on the radiator and the only way to get at this bracket is with a wrench, which I know is not right to use in this case, but I can't get at it with a screw driver.
Anyone have ideas - is this a bad hose, or a case of being too paranoid and not tightening it enough??
When the engine is warm, there's NO leaking what-so-ever!
