Some of the segments of the antenna on my 1989 BMW 325is will occasionally get stuck. The antenna is the kind that telescopes. Sometimes when it retracts, the final segment gets stuck. Also, the sunroof tracks on this car need some greasing up.
I went to Kragen and saw some sort of silicone spray as well as "White Lithium" lube. Both are aerosol-based, and the labels on both basically say the same thing. I assume that both will do the job, but I'm worried that dirt and dust will be attracted to the stuff. Which one will minimize this? Thanks.
