The car is an 1991 Infinity Q45.
It seems that just changing the oil should not make it run considerable worse but here is what I did.
I switched from standard oil to synthetic 5-40 (Chevron Delo 400).
I emptied the old oil and filter out and then ran some cheap 10-40 chevron oil through to rinse it. I then put on the new filter and added the Chevron Synthetic 5-40. It was immediately hard to start (cranked a lot before starting) and ran rough at certain speeds. Everything I know about cars says this isn't possible. I did have to take the switch off the aircleaner to remove the air cleaner because they hide the filter beneath it but I put it back on....so I am scratching my head on this one. Does anyone have any ideas?
Thanks
Thanks
