Usually figures given for U.S. equipment suppose dry assembly, unless stated otherwise. The proper thread stretch depends on whether the engineer calculates the required torque assuming dry or lubricated threads. The table below gives generic torque values for dry and lubricated threads. The point was made to check first. You need to find out for sure, because lubing the threads and bolt head will definitely result in generating a higher stress (thread stretch) on the bolt than what the torque wrench tells you that you are generating. Thread locking compounds, such as Loctite, have a lubricating effect, as well.
U.S. BOLT TORQUE SPECIFICATIONS
Torque in pounds-foot
2 2 5 5 7 7 8 8 Socket head cap screw Socket head cap screw
Bolt Dia. Thread per inch Dry Oiled Dry Oiled Dry Oiled Dry Oiled Dry Oiled
1/4 20 4 3 8 6 10 8 12 9 14 11
1/4 28 6 4 10 7 12 9 14 10 16 13
5/16 18 9 7 17 13 21 16 25 18 29 23
5/16 24 12 9 19 14 24 18 29 20 33 26
3/8 16 16 12 30 23 40 30 45 35 49 39
3/8 24 22 16 35 25 45 35 50 40 54 44
7/16 14 24 17 50 35 60 45 70 55 76 61
7/16 20 34 26 55 40 70 50 80 60 85 68
1/2 13 38 31 75 55 95 70 110 80 113 90
1/2 20 52 42 90 65 100 80 120 90 126 100
9/16 12 52 42 110 80 135 100 150 110 163 130
9/16 18 71 57 120 90 150 110 170 130 181 144
5/8 11 98 78 150 110 140 140 220 170 230 184
5/8 18 115 93 180 130 210 160 240 180 255 204
3/4 10 157 121 260 200 320 240 380 280 400 320
3/4 16 180 133 300 220 360 280 420 320 440 350
7/8 9 210 160 430 320 520 400 600 460 640 510
7/8 14 230 177 470 360 580 440 660 500 700 560
1 8 320 240 640 480 800 600 900 680 980 780
1 12 350 265 710 530 860 666 990 740 1060 845
BOLT TORQUE FACTORS
LUBRICANT OR PLATING TORQUE CHANGES
Oil, Reduce torque 15% to 25%
Dry Film (Teflon or moly based), Reduce torque 50%
Dry Wax (Cetyl alcohol), Reduce torque 50%
Chrome plating, No change
Cadmium plating, Reduce torque 25%
Zinc plating, Reduce torque 15%
Baseline torque is calculated for a non-lubricated, unplated bolt.
For spark plugs, I would call the manufacturer and ask them what torque they recommend if you use antiseize. Stripping threads is one of the great sinking feelings in life. Act in haste, repent at leisure.
[ July 17, 2005, 08:37 AM: Message edited by: TxGreaseMonkey ]
