JHZR2
Staff member
Hi,
I have a little problem with NOx in my 91 BMW 318i. It barely failed, then it barely passed. I have checked for intake leaks, and have not been able to find any, and all seems good.
However, after an oil change, I was testing the oil cap for seal, and then I pulled the dipstick (both with the car running). Just cracking the oil filler caused the engine to sputter and almost stall, but I could pull the dipstick all the way out, and there was no change.
Shouldnt removal of the dipstick be a source of unmetered air, and result in a change in idle as the engine goes lean?
Maybe there is just slight enough of a leak thatit still can idle perfectly smooth and run great, yet its just enough to lean out the mixture so there is no CEL, but the combustion temp increases, causing NOx to form.
Sound plausible??
Thanks,
JMH
Sound plausible??
Thanks,
JMH
