I am not sure about the way my engine is running. This is my 1990 Jeep Comanche with 157K miles on it. It was parked in my Dad's barn from Oct 1999 to Feb 2005 and had
I have changed the plugs, thermostat and O2 sensor w/help from BITOG members, plus brakes, calipers and other non-engine parts. I am on the rinse phase of my first ARx treatment and it has made a huge improvement in the engine. I wish that I had removed the valve covers and taken pictures.
The thermostat that I installed was a 195 oF thermostat from Advance Auto. The previous thermostat was stuck open. The coolant temp now rises to the appropriate temp and levels off according to the gauge, but the hood and engine seem to be very hot after driving.
I probably need to do a coolant system flush, but I am hesitant as I have never done this before. This is not my daily driver, but it is a great little truck for trips to Home Depot or the landfill. I have a lot of sentimental reason to keep this truck running forever if possible.
Does any else have an older Jeep 4.0L with similar mileage? If the temp guage is at the appropriate setting should I assume that this engine was designed to run this way? Any thoughts or suggestions?
Thanks.
Thanks.
