I am having trouble changing the serp belt on my daughter's 1998 Jeep Wrangler TJ with the rare 2.5 L four cyl. 150 CID engine. It has two idler pulleys. The one that looks like it is the tensioner pulley is the one on the driver's side near the power steering pump. I have lossened the long 15mm bolt that runs diagonally thru the pulley bracket. Even though completely lossened, the belt is still tight as ever. How do you get the pulley to release the tension on the belt? Is it frozen? Is there another bolt hidden? Anyone with a FSM to quote me the correct procedure? Thanks for your help! Jim
