I have a car that has been in storage and it hasn't been driven on the road in a couple of years, but I do start and run it frequently.
The power steering pump/reservoir has been squealing when I turn the wheel; even slightly. The wheel also feels "heavy".
I first removed as much of the old fluid that I could using a turkey baster. I removed about 8 oz. I put in some fresh fluid (Prestone 2-in-1 Power Steering Fluid with Stop Leak and Seal Conditioners, [black bottle]). I ran it for a while, turning the steering wheel back and forth.
It got better, but not like it should be. I then used a hand-cranked pump and I was able to remove more fluid, about 13 oz. I refilled it with more fluid; (6 oz. of Lucas Power Steering Fluid and the rest, Valvoline MaxLife Power Steering Fluid, I was told this might be a good combo) but the steering has gone back to the way it was.
I thought I would leave the Lucas/Valvoline mix in for a couple of days and start and run the car again. If there is no improvement after a few days, I was wondering if I should drain out this fluid again, and maybe add some type of cleaner to free up any stuck valves inside the pump.
Is there a cleaner that can be added to help unstick things, or should I just continue to drain and refill with fresh fluid?
Some people have suggested adding Dexron III transmission fluid, or CD-2 Oil Detergent, then removing it and adding fresh fluid.
Any ideas?
Thanks in advance!
Any ideas?
Thanks in advance!
