well i been having this idle problem for a long time in my 99 mercury villager. it idled fine and pass smogged but it seemed to double beat on the idle, kinda like looping really fast.
i found out for 3 years my intake filter hasnt been sealing due to a warped air box.
so now i found the reason to my idle, so i tried to clean it with sea foam. it was still the same.
everyone here raved about amsoil power foam so i picked up a bottle and gave it a shot.
well the directions said use the whole bottole, so i instead used half, and wanted to do a second application.
so the car kept shutting off when i sprayed in the MAF sensor...so i took that off and sprayed in the throttle body, it kinda bogged and i wanted a good spray in there so i revved a little and at the same time sprayed half the bottle.
the engine sputterd badly. then it was fine, but OH THE FUMES~!!! it came out soo white..lol
so i was done and i heard it idled good so i drove it around to get the smoke out...good stuff.
then changed oil, and now no problems soo far.
i think ill use this product in all my cars.
should i had used the whole bottle?
thanks for reading!
thanks for reading!
