I recently purchased a retired police car - a 1995 Chevrolet Caprice with 109,000 miles. Oil pressure is good at all times, vacuum is a steady 18" at idle. Oil loss (consumption) is about 1 qt/1400 miles. I recently had a bad engine miss which got steadily worse. I changed the plugs and wires and found that the #8 cylinder (passenger side near the firewall) spark plug electrode was a blob of oily goo. All of the other plugs were fine. Changing the plugs solved the miss, but I obviously have a problem in that cylinder. That cylinder is near the breather in the valve cover, and I've noticed a fair amount of oil on the valve cover and the breather. I am beginning to think that the oil return in that cylinder head has sludged up, restricting the return flow of oil from the head which is then getting sucked into the cylinder. Before I pull the valve cover, I was wondering if there is anything else I could do to pinpoint my diagnosis, and if it holds, what I could do, like auto-rx, to clean up the oil return without pulling off the valve cover.
