Is it recommended to use some sort of sealant (grey) on the outside of the pinion seal and or on the spindle threads (gear threads) where the washer and nut compress?
Not sure if I should just clean all surfaces and install the pinion seal dry without adding anything.
Any advice is greatly appreciated
