I have a 2020 Kawasaki Brute Force 300 and I want to change out the transmission and final rear gear oil. The manual says to use SAE#90 for the transmission case and SAE#80 for the final rear gear. It doesn't specify GL-4 or GL-5 or anything like that. It is an automatic CVT transmission. Now I went went to the dealer yesterday, they gave me Honda HP Trans 80w85 (which is a pink/red color) and told me to use in both Trans and Rear. I found it weird because it's Honda brand and it's not what I drained out of the transmission. Is the Honda HP ok to use and if not, what should I use? I don't want to void the warranty or mess anything up.
