Hi all,
I'm trying to figure out what if any gearbox or engine mount is gone.
They seem fine when driving in gear through the rev range.
It bangs quite a bit when starting and turning off, a lot more the I'm used to first diesel car but i have driven other diesel and haven't felt it like this before. also when you put the clutch in when the engine is above idle (i.e slow first gear and then suddenly put in the clutch) the engine, not the car lurches, not sure if forward or backwards.
Here are the pictures for the gearbox mount I forgot to take picture of the rest but the all look the same, no rips, tough but not rock hard.
What I'm trying to figure out is this the normal for other small diesel or do i need to look for other mounts that might be causing it.
