Originally Posted by shibby6600
I have some of the slightly older 38846 stands. They are assembled the exact same, but maybe didn't have penetration issues with the weld? Wonder if welding straps between the two halves would solve the problem or strengthen it.
For what it's worth, everyone looking at different brand jacks that have the same construction, be aware you could have the same issues. Would not surprise me in the slightest if every jack made in China comes from only a couple different factories that are owned by the same person and use the same assembly process.
Additional note, even if they use a pin does not mean they will not split at the seam weld.
That goes for anything that is welded, even the Made in the USA stands have welds.
