I got a tube of John Deere polyurea grease, part #TY6341, for greasing control arm ball joints. I used a lithium/moly type grease on them previously. Now I find that there's a difference between "shear stable" polyurea grease and "conventional" polyurea grease, where the shear stable type is compatible with lithium grease and the other type isn't. See:
www.machinerylubrication.com/Read/1865/grease-compatibility
(Found this out from an older posting on here.)
The problem is I can't find any explanation for how to know which type of polyurea grease I have. Anyone know about this? There's no way to clean the old grease out of the control arm joints. I'd like to use the grease I already got if it will work.
