Originally Posted by Normac
Originally Posted by gathermewool
How does she shift? If it's easy to do, I'd be tempted to get some cheap new MTF in there (or ATF, if that's what it calls for)
I'm sure others will be able to give better recommendations, if she's not shifting well.
Actually shifting is quite smooth and easy.
That thought had come to mind (MTF), but I hate to mess with it as smooth as it is right now.
I totally agree. I wouldn't do anything with the MTF in that case. It really seems as if you lucked out.
One thing I would NOT due is assume that this thing is going to die on you in the next six months. If you're able to do the work yourself and things are due, I'd do them (e.g., coolant, timing belt, drive belt, etc.) If you can't do these things yourself, then I'd just let it ride!
