Good Morning! I am curious if anyone has a Stihl leaf blower (BR700 or close) and has experience with what oils and mix ratios work best. As a former engine design and testing engineer I always stick to the books but I just so happen to some OEM recommendations are cost based and pass internal tests vs. are actually better long term. That stated and what sparked this thread is I have two BR700's right now, right next to each other creating a very simple A-B compassion test. His is significantly smoother running than mine. He doesn't know the oil or mix ratio yet as he just got it but I think that could make the difference. Also, both have new ethanol free gas.
Has anyone played with these and found a difference in operation with oil types or mix ratios? I wold never go leaner on the mix but maybe a 40:1 vs 50:1 smooths things out? heck I might just need a new plug too...
Thoughts?
Thoughts?
