Planes fly over white house after speech
by 1978elcamino - 07/04/20 10:16 PM
Code reader advice
by 53' Stude - 07/04/20 10:05 PM
People driving less / motor oil prices?
by 1978elcamino - 07/04/20 10:02 PM
Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
Want to bet on my luck? (atf to "save" transmission)
by Snoman002 - 07/04/20 06:10 PM
Too Much Zinc = Corrosion?
by viscous - 07/04/20 06:00 PM
New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
SilentC, paolo9fla, SunnyB, Mullady76, Axia2
71848 Registered Users
22 registered members (bbhero, Falcon_LS, bernardch, edyvw, dishdude, 77GrandPrix, 3 invisible), 756 guests, and 23 spiders.
Topics307,436
Posts5,311,045
Members71,848
Used Brake Calipers #5466703 06/30/20 09:38 PM
T
troutfisher Offline OP
T
My Silverado front left caliper caused me some problems on the way home today,locked almost completely up and required about me to drive very slow,with heavy throttle for about 5 miles.
Rotor is toast,and pads got really burnt up. Everything got very hot,the wheel was scalding hot.
So anyways it needs a caliper,the local Auto recycling place has one off a 2013 express Van that had 44k miles on it for $30 with a $15 core and 180 day warranty.
Should I give it a shot to save 40 bucks over a rebuilt carquest one or is it to risky. Anybody have any experience with junkyard calipers vs the rebuilt at the big chains?
Thanks
Re: Used brake calipers [Re: troutfisher] #5466708 06/30/20 09:46 PM
K
Kibitoshin Offline
K
If the calipers aren't excessively rusted, pistons aren't damaged/seized you should be fine with junkyard calipers.
Replace the rubber brake lines whether you get used or reman calipers. It's possible the brake hose internally collapsed causing the caliper to lock up.
Shin Gekiretsu Shin'ou'hou
02 Chevy Silverado C1500 V8 5.3L
Intertrashional maXXXforce 4300 Box Truck
Re: Used brake calipers [Re: troutfisher] #5466720 06/30/20 10:36 PM
slacktide_bitog Offline
Get the Raybestos Element3 all-NEW calipers on Rock Auto. They are all-new, not reman
You should replace both front calipers.
Re: Used brake calipers [Re: troutfisher] #5466722 06/30/20 10:39 PM
Chris142 Offline
Calipers lock up because dirt gets in them. The used ones may be no better that what you have. Get proper rebuilt ones.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Used brake calipers [Re: troutfisher] #5466738 06/30/20 11:59 PM
R
Reddy45 Online Content
Online Content
R
Didn't have the option to stop and try to fix it or tow it? All that heat probably put a lot of surrounding parts in jeopardy.
Re: Used brake calipers [Re: Reddy45] #5466762 07/01/20 03:43 AM
E
eljefino Offline
E
Ya, you're lucky you didn't boil the brake fluid and lose all braking power.
Re: Used brake calipers [Re: troutfisher] #5466777 07/01/20 05:19 AM
Silverado12 Offline
I've had a total of 3 calipers stick in my lifetime on different vehicles all from setting for 6 months or so. Just get a NAPA rebuilt one. Last time I bought one they were $26.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Used brake calipers [Re: troutfisher] #5466794 07/01/20 06:26 AM
B
Bottom_Feeder Offline
B
Yes, exactly. These are your brakes you're talking about. If you're going to do it, do it right and get remans at least!
Re: Used brake calipers [Re: troutfisher] #5466808 07/01/20 07:08 AM
R
Railrust Offline
R
Actually I disagree with most of the people on this thread.
Rebuilt calipers can be pretty poor in quality and can easily end up seizing on you a year or two down the road. Upon close inspection of these things you’ll notice some scratches and knicks on surfaces that just shouldn’t be there. Think about it, they are being rebuilt because they failed once already...and they are being “rebuilt”, god knows where and by god knows who. I’m not saying it’s all catastrophic, I’m just saying the used caliper with 44k miles on it might actually be a better option. My 2 cents.
2018 Chevy Silverado 5.3 (sold, with 52,000 stumbling and bumbling miles)
2007 Lexus LS460 (deceased)
2008 Honda CRV
2016 Toyota Avalon XLE
(Whatever synthetic oil is on sale or rebate)
Re: Used brake calipers [Re: Railrust] #5466848 07/01/20 07:57 AM
T
Trav Offline
T
+1 That is about the size of it, reman/rebuilt are pretty bad. Used is okay if it is in good shape or Raybestos Element 3 new are very good.
Re: Used brake calipers [Re: troutfisher] #5466853 07/01/20 08:01 AM
Donald Offline
You can buy a rebuild kit for a few dollars and rebuild the one you have. Pretty easy just need a disc brake hone.
I agree with replacing the flex brake lines if they are over 10 yr old and you had a problem that makes them suspect.
How important to save the $40?
2015 Ford F-250 w/Powerstroke
Re: Used brake calipers [Re: Trav] #5466882 07/01/20 08:40 AM
M
MarkM66 Offline
M
Looking at these for my Accord and they're about the same price as Cardone rebuilt, that need a core return.
Makes me wonder why rebuilts aren't obsolete.
Re: Used brake calipers [Re: MarkM66] #5466906 07/01/20 09:06 AM
T
Trav Offline
T
New are not available for all vehicles so you may need to rebuild them, those I do myself now if the parts are available.
Re: Used brake calipers [Re: MarkM66] #5467139 07/01/20 02:12 PM
Dave9 Offline
Because the Element3 are often significantly more expensive. Last vehicle I did brakes on, those were 75% higher priced. Granted there's some value in not having to drive or mail in cores, and in getting new calipers, but some will just do the cheapest fix possible.
Re: Used brake calipers [Re: troutfisher] #5469385 07/04/20 11:38 AM
T
T
Went to the junkyard to look at the used caliper for $35,awful looking caliper,Rusty and full of dirt. So I left went to the Chevy Dealer 2 miles up the road,got a brand new one for 110.00 out the door,did not come with bracket.Did not need one just cleaned + greased the the pins.So got a new rubber to hard line hose at Napa and a set of pads and rotors.
All fixed now, no more problems,still waiting on my vacuum bleeder from Amazon,to get the pedal perfect,but probably won't ever even think about junkyard calipers again,unless it's a farm use truck or something like that.
Thanks for the help.
