Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Generator oil
by Eddie - 07/05/20 01:51 PM
This never ceases to amazing me
by SLO_Town - 07/05/20 01:46 PM
Empty shelves and lack of variety.
by sloinker - 07/05/20 01:17 PM
Mann HU816 (28 month service)
by Barwich - 07/05/20 12:23 PM
Napa Gold 1348 and Mahle OC148 C&P
by BeerCan - 07/05/20 10:38 AM
Dead rechargeable batteries on cordless drill
by 97tbird - 07/05/20 10:35 AM
2018 Silverado 6.0 Idle Stumble
by Phishin - 07/05/20 10:20 AM
U.S. Gasoline Production
by Snagglefoot - 07/05/20 07:39 AM
Trying to save an otherwise junkyard bound car
by agarb - 07/05/20 07:08 AM
Code reader advice
by 53' Stude - 07/04/20 10:05 PM
People driving less / motor oil prices?
by 1978elcamino - 07/04/20 10:02 PM
Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
TacoFergie, electro, SilentC, paolo9fla, SunnyB
71850 Registered Users
92 registered members (antonmnster, Arrechera, Atrocious, andy2001, 4WD, 8 invisible), 2,018 guests, and 26 spiders.
Topics307,449
Posts5,311,391
Members71,850
Use of multiple fluid types. #5465998 06/29/20 11:26 PM
M
Moonboy188 Offline OP
M
Gonna try to keep this short. 05 F-150. Transmission calls for Mercon-V. Dipstick tube broke off, and lost a bunch of fluid.My kid drove it home with no issues, but the next day it wouldn’t move in gear. I had an eclectic selection of ATF’s, and I got some bad advice that ATF’s we’re all generally the same so I poured them in. According to the other forums I’ve asked, I get all kinds of answers. I used 1 liter of Motul Dex-lll, and 1 liter of Motul ATF Vl(Mercon LV), and 2 1/2 quarts of O’reiily’s Mercon. Started the truck, and it now moves. Only ran it for the fill, and moved it forward, and back for approx 5 feet. Went to the F-150 Forum, and they’re scaring the crap outta me. Will I blow this tranny up leaving that fluid in there? and if so how do I get all of the fluid out of the torque converter? Leave it alone , and drive it? drop the pan for partial flush? or tow to tranny shop, and have it passive machine flushed? Any advice would be much appreciated!
Re: Use of multiple fluid types. [Re: Moonboy188] #5466006 06/30/20 12:04 AM
H
HyundaiAbuser Offline
H
Its not going to spontaneously combust however I would do a cooler line flush with a licenced mercon V. I recently did one with Castrol import multi vehicle on my step fathers 2004 f150 and its never shifted better.
https://www.walmart.com/ip/Castrol-TRANSMAX-IMPORT-Multi-Vehicle-Automatic-Transmission-Fluid-1-Gallon/176732896?wmlspartner=wlpa&selectedSellerId=0&&adid=22222222227240730028&wl0=&wl1=g&wl2=c&wl3=286561461561&wl4=aud-430887228898:pla-487187202457&wl5=9024253&wl6=&wl7=&wl8=&wl9=pla&wl10=8175035&wl11=online&wl12=176732896&veh=sem&gclid=Cj0KCQjwoub3BRC6ARIsABGhnyaynVPYuPtf7fghN-f7qVT2ETHhpbxvs-2HQhal0dLidncCzPab8WUaArSyEALw_wcB
3 gallons of this
https://shop.advanceautoparts.com/p...jIyA6EYIhAaAviLEALw_wcB&gclsrc=aw.ds
this disconnect tool
plug the radiator port as I had some backflow. Then I would do it again in about 10k miles and not have to worry for a good while.
03 Hyundai Tiburon:
PP High Mileage 5w30
Redline MT85
94 Mazda B4000 (RIP)
Supertech 10w40 High Mileage
Valvoline Maxlife
Re: Use of multiple fluid types. [Re: Moonboy188] #5466030 06/30/20 02:35 AM
R
RyanY Online Happy
Online Happy
R
The mix may or may not cause problems in the future, but the stress is obviously a problem right now! I would follow the advice from @HyundaiAbuser and do a cooler line flush.
Licensed Mercon V is obviously a good choice, but IME the universal fluids (Maxlife, Amalie, etc) have worked just as well as licensed fluids. If you go with universal, definitely stick to one that is specifically recommended for that application.
2007 Cadillac CTS 3.6L >131k miles; mix of PUP/Magnatec 5W-30 + ACDelco PF2129G
2012 Honda Odyssey EX-L >109k miles; QSUD 0W20 + STP S6607XL
Re: Use of multiple fluid types. [Re: RyanY] #5466034 06/30/20 03:01 AM
B
blufeb95 Offline
B
I'd just use license Merc V in applications that call for it a lot of mult vehicle ATFs have went more towards being low viscosity to be more compatible with newer transmission calling for Dex VI and Mercon LV and similar. Ford recommends using Mercon V in applications that originally called for Mercon but does not call for Merc LV to be used in applications where Mercon V was originally specified like with GM who recommend to use low viscosity Dex VI in applications that previously called for high viscosity fluids Dex III or Dex II-E or older... Wally world sells SuperTech Merc V for just under $5 a quart.
Re: Use of multiple fluid types. [Re: Moonboy188] #5466037 06/30/20 04:14 AM
L
Lubener Offline
L
It is a good time to drain it. I would flush the fluid out at the cooler line. Then drop the pan to clean the pan, magnet and replace the filter.I would do both a flush and pan drop. It probably was never changed and a filter change is just as important as the fluid.. Use ONLY Mercon V, no universal or Maxlife fluid. I never believed in one fluid "fits all" and if they were good, it would have been put in there at the factory. They can be identified as saying "suitable" for use in Ford transmissions, stay clear of them.. A complete change is best, take it to a transmission shop if you do not want to tackle it.You put all kinds of fluid in there except the correct one.
The "thinking" man's friend.
Re: Use of multiple fluid types. [Re: HyundaiAbuser] #5466171 06/30/20 08:45 AM
M
M
Thank you. On the cooler line flush. Am I just disconnecting one line, the flow out line? And, which one is that? Drivers side/passenger? Then adding through fill tube as it pumps out of the line into my plastic catch tub? Also how many quarts should I flush through? I will drop the pan, and change the filter as well. Says 9 quarts in the torque converter, and 4 in the pan. Sorry to be a pain in the [censored], just wanna get it right. Thanks again!
Re: Use of multiple fluid types. [Re: Moonboy188] #5466177 06/30/20 09:04 AM
MolaKule Offline
Global Moderator
Global Moderator
Fill it to the point where you can drive it to the mechanics shop or transmission shop get the dipstick replaced first.
Any Mercon V or Mercon V replacement/equivalent will work.
I would take a sample of the fluid that is currently in it and send it off for a particulate count.
"So many shows out there dumb-down the country. It's so admirable to be part of a show that wants people to think." (David Krumholtz 'Charlie Epps' of NUMB3RS)
Re: Use of multiple fluid types. [Re: Moonboy188] #5466191 06/30/20 09:16 AM
CT8 Offline
Nope it won't hurt but I have a feeling by the wording of your post that it needs to go have the dipstick stick replaced and the pan dropped filter replaced and new fluid .
2015 F150 2.7
2018 F350 6.2
Re: Use of multiple fluid types. [Re: Moonboy188] #5466205 06/30/20 09:28 AM
F
Fattylocks Offline
F
I'm guessing you replaced the dipstick tube.
Not the the first I've heard of these failing. Salt eats them up in the rust belt.
You might have a plug in the bell housing that grants access to a torque converter plug.
If your dropping the pan, good idea, you'll get about 4 1/2 quarts out. Drain the converter if you can.
Tons more in there..
I'd disconnect the cooler lines at the lowest point and let them drain.
Refill with Merc V.
94 Caprice Wagon Daily driver sold
05 Focus Wagon 2.0 Duratech city car sold
05 Mustang GT Convertible sold
05 P71 ex Homeland Security
12 Ford Explorer XLT Base
11 Nissan Titan SV King cab 4x4
Re: Use of multiple fluid types. [Re: Moonboy188] #5466289 06/30/20 11:31 AM
H
H
On the radiator there are two metal lines on the driver side, there is a plastic clip you have to take off then take the disconnect tool and push it into the bushing that the line goes into. While pushing it in pull on the line and it should come out. I ran a clear plastic hose from the line to a bucket and stopped every two quarts to top off. I also placed a rubber plug in the radiator hole. I ran 12 quarts when I did mine and I had fresh fluid coming through the tube.
If I recall correctly, castrol import multi vehicle is licensed for mercon V.
03 Hyundai Tiburon:
Redline MT85
Valvoline Maxlife
Re: Use of multiple fluid types. [Re: Moonboy188] #5466320 06/30/20 12:27 PM
B
Barkleymut Offline
B
From the Castrol website TRANSMAX™ IMPORT MULTI-VEHICLE
Castrol® Transmax™ Import Multi-Vehicle is designed for use in most Honda, Toyota and Nissan vehicles as well as many other imported brands. It exceeds the requirements of the JASO-1A performance standard created by Japanese auto manufacturers. It also exceeds DEXRON®-IIIH, MERCON®V and MERCON® requirements.
Interesting, I never knew that....I have 6 or 7 quarts from years ago when I changed out the ATF in mom's Pilot. Not sure that I feel brave enough to use it in my Mustang.
09 Vue 2.4L 4spd AT/ 09 Flex 3.5L / 96 F150 5.0 5speed / 07 Mustang GT auto
Re: Use of multiple fluid types. [Re: Moonboy188] #5466460 06/30/20 03:53 PM
T
Trav Offline
T
Check for an inline thermostat on that on the pass side (not sure if they still used it in that location in 05), you may need to remove the line from the trans and put a fitting in to connect to. I cant see any harm done from the fluids, running it that low???
