Pentosin Mania
by Snagglefoot - 07/01/20 11:30 PM
Spills. Synthetic vs petrolium
by Chris142 - 07/01/20 10:35 PM
Michelin Pilot Sport All-Season 4
by FordFocus - 07/01/20 10:04 PM
NGK Ruthenium Spark Plugs
by Deontologist - 07/01/20 07:49 PM
Ram Truck Speaker Upgrade Questions
by edhackett - 07/01/20 07:41 PM
OLM SCREWED UP
by demarpaint - 07/01/20 06:12 PM
Have Valvoline European 5w-40. Use in Cummins?
by RetiredGuyOR - 07/01/20 06:06 PM
Change in evaporation rate over time?
by mosschops - 07/01/20 05:56 PM
17 Golf overzealous OLM/Minder
by lawrencerd - 07/01/20 04:24 PM
First cell phone
by Chris142 - 07/01/20 04:08 PM
Motorcraft FL836 Specifications
by viscous - 07/01/20 03:41 PM
Chipmunks - Damit.
by PontiacHO - 07/01/20 03:37 PM
27/18k portable genset oil.
by 1978elcamino - 07/01/20 03:31 PM
Saw a new BMW and had to do a double take.
by wemay - 07/01/20 02:55 PM
Seems like there is less activity on BITOG
by SLO_Town - 07/01/20 02:21 PM
Rock Auto horrible customer service
by cknight49090 - 07/01/20 02:09 PM
Mobil 1 rebate hassle
by cknight49090 - 07/01/20 02:00 PM
RetiredGuyOR, BretBouer, JKMark, Tugcan, George_Robert
71821 Registered Users
17 registered members (Char Baby, blufeb95, Bailes1992, ArrestMeRedZ, Bjornviken, 3 invisible), 595 guests, and 28 spiders.
Topics307,388
Posts5,309,612
Members71,821
Install Spindle Assembly #5465888 06/29/20 07:23 PM
T
tnt31 Offline OP
T
I need to replace one of the spindle assemblies on a Craftsman LT2500 (247 series rider so an MTD). It has been a good mower. The spindle arrived today. It is a Cub Cadet (reboxed MTD) spindle.
Question is the four bolt holes in the spindle do not come threaded. Should I use the self tapping bolts to cut the threads prior to installing or just do it as I install it in the deck? Any secrets to do it correctly and not break the bolts or the spindle? New assembly came with new bolts.
Thanks
Re: Install Spindle Assembly [Re: tnt31] #5465900 06/29/20 07:51 PM
R
Rand Offline
R
all the spindles I've replaced had carriage bolts with nuts.
Re: Install Spindle Assembly [Re: tnt31] #5465922 06/29/20 08:23 PM
M
Mr_Joe Offline
M
Yes, I thought most use a bolt/nut combination. The nut ends up on the bottom side of the deck, near blades.
Look at how the old/bad spindle comes off.
Re: Install Spindle Assembly [Re: tnt31] #5466046 06/30/20 04:52 AM
dlundblad Offline
I wouldn’t use a carriage bolt. I can see that being problematic if you ever need it off again.
Rather than threading the spindle holes, can you just have a bolt running completely through? Nut facing up if possible. (Not sure what kind of clearance you’ll have at the pulley.) Use SS bolts or anti seize. Threading the holes yourself also assumes the metal is the same quality as the original. If it’s too soft, I can see the threads blowing out.
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: Install Spindle Assembly [Re: tnt31] #5466057 06/30/20 05:48 AM
V
vwmaniaman Offline
V
I have always just used the self tap bolts that come with the new spindle. That is what the factory did. No need to overthink this.
Don't waste your time on a slipshod repair.
Re: Install Spindle Assembly [Re: tnt31] #5466093 06/30/20 06:48 AM
R
RAR Offline
R
When I rebuilt my Cub Cadet 42” deck a few years back, I replaced both spindle assemblies, belts, blades, etc. The replacements came with self tapping bolts; it went together nice and tight, and that tractor had a few more years of service before I sold it at an auction. Don’t use bolt and nut combos, because they will shake loose eventually and damage the deck or worse. Just my two pennies... 😎
2019 Ram 1500 Big Horn 5.7 4x4
2015 Ram 1500 Tradesman 5.7 4x4
2011 Dodge Charger Police 5.7 RWD (prepping for sale)
2010 Ford Crown Victoria PI (Decided to hold onto for a loaner car)
Re: Install Spindle Assembly [Re: tnt31] #5466164 06/30/20 08:40 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
How is the original installed? Is there something unique to the replacement that makes the installation different?
Re: Install Spindle Assembly [Re: tnt31] #5466445 06/30/20 03:15 PM
A
andyd Offline
A
I just did the same to a 42" craftsman deck The spindles were tapped Self tapping screws will do, I s'pose. I would run each screw about 1/2 way in before I tightened anything grin2
Thick oil is better grin2
Re: Install Spindle Assembly [Re: vwmaniaman] #5466542 06/30/20 05:38 PM
T
tnt31 Offline OP
T
Unless if too difficult I will try tapping it with the self tapping screws as I install the part. I saw some videos where the person ran the screws in tapping the threads as a separate step then backed the screws out and then installed the spindle. I would think if that was how the part was designed to be installed it would already be pre-tapped. (I did see some aftermarket spindles that were pre-tapped but most were not including the OEM part) Hopefully will get to it this weekend.
