Just a FYI, you may want to adjust where the donate button is.
I spent about 10 minutes looking for how to donate here, and it was not till I did a google search and found THIS THREAD that I figured it out.
It is only visible of you have the left column turned on, which I do not.
Not sure how many other members have it turned off as well, so maybe missing out on some donations if that is the case.
Maybe have a sticky in this sub-forum or have the donate button at the bottom of the forums section?
