Forums Migration
Please read this thread
2017 CR-V Next Oil
by Ruby2013Elantra - 07/08/20 02:31 AM
Silver Windshield Sun Shades
by rrretiree7 - 07/08/20 02:04 AM
Castrol Edge PIck-Up
by Gene K - 07/08/20 01:51 AM
Safety kleen seals.
by Chris142 - 07/07/20 10:58 PM
I do a full detail everything 2 or 3 years.
by SLO_Town - 07/07/20 09:59 PM
Oil Recommendation 2020 GR Supra
by afree - 07/07/20 09:51 PM
I need to drive it more...
by SLO_Town - 07/07/20 09:43 PM
Pennzoil
by BlueOvalFitter - 07/07/20 09:07 PM
100k 06 Fusion 2.3
by Aichiguy - 07/07/20 08:13 PM
CHINA
by buster - 07/07/20 07:52 PM
Darker varnish spot on rocker arm
by Spetz - 07/07/20 07:29 PM
AC Delco Dexron VI $18.76 a Gallon Amazon
by Matt1980 - 07/07/20 07:17 PM
ALS labs change in fuel dilution test
by LotI - 07/07/20 06:50 PM
Archery high tech
by CourierDriver - 07/07/20 06:42 PM
Odd filter issue
by fatrap314 - 07/07/20 06:33 PM
Lexus IS 350 AWD 2016 0W-20
by hotp4nts182 - 07/07/20 06:14 PM
Duh-- Didn't know there was a SIM card.
by csandste - 07/07/20 03:54 PM
Running 40 PSI vs 35
by Mr_Luke - 07/07/20 03:05 PM
fatrap314, hotp4nts182, LeslieX, Mayuraj, thexeve
71876 Registered Users
20 registered members (Bjornviken, Gene K, alcyon, farrarfan1, EdwardC, FnORD, 3 invisible), 727 guests, and 29 spiders.
Topics307,584
Posts5,313,570
Members71,876
Acetone/transmission fluid storage? #5465233 06/28/20 09:48 PM
M
motor_oil_madman Offline OP
M
I have one of those old style oilers where they're made of metal and you pull the lever to oil something. Can I mix some up then just leave it inside one of those oilers? Or is their a risk of it leaking out?
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Acetone/transmission fluid storage? [Re: motor_oil_madman] #5465234 06/28/20 09:48 PM
M
M
Also what is the mixture? 50/50?
Re: Acetone/transmission fluid storage? [Re: motor_oil_madman] #5465250 06/28/20 10:09 PM
A
Avery4 Offline
A
Depending on what the can and its pump are made out of, maybe. Acetone is a pretty aggressive solvent and can destroy plastic and rubber parts, so the pump and/or its seals may be damaged. Make sure the can seals when not being pressed, the acetone may evaporate or the vapor pressure may push fluid out of the container otherwise. Be sure to shake the container to mix the acetone and ATF together before using it. They don't mix well, the acetone settles to the bottom over time. And yes, the mix is 50/50.
Re: Acetone/transmission fluid storage? [Re: motor_oil_madman] #5465273 06/28/20 10:33 PM
F
ford46guy Offline
F
Acetone is sold in plastic bottles for nail polish remover. I guess you can pour off half in another bottle and store it in there?
95 Tbird V8 240K PP SYNTH ULTRA 5W30
98 MGM 160K M1 HM 5W20
96 Explorer EB V6 159K PP SYNTH HM 5W30
95 Conti 155K MC 5W20
11 GS350 90K PP HM 5W30
Re: Acetone/transmission fluid storage? [Re: ford46guy] #5465288 06/28/20 11:14 PM
M
M
I've only seen it sold in metal quart or gallon cans.
Re: Acetone/transmission fluid storage? [Re: motor_oil_madman] #5465301 06/28/20 11:55 PM
A
Avery4 Offline
A
It is sold in plastic bottles as well https://www.dollargeneral.com/studio-selection-100-acetone-nail-polish-remover-10-oz.html
Re: Acetone/transmission fluid storage? [Re: motor_oil_madman] #5465411 06/29/20 07:20 AM
K
Kira Offline
K
There are plastics and plastics. Also, the acetone content is low in nail polish remover.
My favorite ATF/acetone jar is the crinkly, clear Boush and Lomb contact lens solution containers.
They have a flip top and a teeny-weeny hole so you can shoot accurately
Re: Acetone/transmission fluid storage? [Re: Kira] #5465439 06/29/20 08:11 AM
F
ford46guy Offline
F
Says 100% acetone on the ones I buy :lol:
Works well on rust, I put a bit in a dollar tree spray bottle with ATF and spray.
The dollar tree bottle is distorted but sprays fine.
Works wonders on rusty hardware. As good as kroil or pb for what I use it for.
Re: Acetone/transmission fluid storage? [Re: motor_oil_madman] #5465528 06/29/20 10:32 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Id just keep it in a glass jar and disperse some when needed. As this stuff isnt pressurized/aerosol, its hard to get everywhere, and other solutions are sometimes more convenient.
So big jar with a good amount, then a baby food jar with a little bit, applied with an acid brush... or items dropped in and shook.
It does separate, so shake!
And use PBlaster where aerosol is needed
Re: Acetone/transmission fluid storage? [Re: motor_oil_madman] #5465534 06/29/20 10:41 AM
Yah-Tah-Hey Offline
Most brake cleaners are acetone.
Re: Acetone/transmission fluid storage? [Re: motor_oil_madman] #5465572 06/29/20 11:26 AM
A
Avery4 Offline
A
Some plastics can handle it no problem, there is 100% acetone nail polish remover that comes in plastic bottles the top on the metal cans is made from plastic too. I personally wouldn't keep it in a glass jar because it's fragile and I am clumsy and would certainly knock it over at some point and spill flammable liquid everywhere.
Re: Acetone/transmission fluid storage? [Re: motor_oil_madman] #5465693 06/29/20 02:15 PM
K
Kawiguy454 Offline
K
Where I live daily heat cycles cause a pump oil can like you describe to usually end up sitting in a puddle from contraction/expansion cycles. I must leave cap/s loose enough to vent container or issues will occur. I had a plastic bottle of machinists blue in wall cabinet and it developed a spontaneous leak and made a yyyuge mess down the shelves. Use a solid container that seals 100%. With large temp change the light volatiles will escape the container over time.
