Brought a pair of Duralast GT brake rotors for my IS250. I've never had issues with Duralast gold so I gave this a try.
Total junk and a waste of time. I've done plenty of brake jobs and have never seen this.
Replaced my oem rotor/pad with Duralast GT and Wagner QS pads. The second I start backing out I get scraping noises from the driver side front. I check and pads on both side(left and right) aren't making 100% contact with rotor.
I think it's a pad retaining bracket so I pull the caliper again to swap in OEM bracket. It did nothing, so I pull the wheels again and swap in OEM pads. It now makes 100% contact but the scraping won't go away.
I start driving thinking a bed in procedure might help but it starts clicking/clunking like I have a bad CV joint when the wheel is turned. I pull the wheels once again to diagnose the issue, swap in my oem rotor on just my driver side and car goes back to normal.
So I think that the rotor is warped and brought it back for warranty. They swapped out the rotor, I pull the wheel again and install it.....SCRAPING AGAIN.
I'm starting to think these rotors are directional and auto zone's system doesn't show it. That or I have really bad luck and got 2 warped rotors in a row.
I will never waste my time with autozone again. Ordering Lexus OEM now. Sick of pulling these pads/rotors for the 5th time in 1 day. Taking this junk back tomorrow morning for full refund
