FJC Foaming Evaporator Cleaner Review
by Reddy45 - 07/04/20 12:10 AM
Ford 351W oil filter best value
by alex16 - 07/03/20 11:12 PM
Super tech euro 5w40 - Canada
by Johan1 - 07/03/20 10:19 PM
Strangers show up for vet's funeral.
by simple_gifts - 07/03/20 09:44 PM
Troybilt tb22ec refuses to run correctly
by Dogred08 - 07/03/20 09:43 PM
Harbor Freight Nitrile gloves
by 1978elcamino - 07/03/20 09:04 PM
Did anyone get a 25% coupon for July 4th?
by 1978elcamino - 07/03/20 08:58 PM
05 4.6 Northstar crank sensor re learn?
by cknight49090 - 07/03/20 08:40 PM
In the year 2049...
by eljefino - 07/03/20 08:05 PM
2-year old oil 124 Spider
by DAC17 - 07/03/20 07:57 PM
New to us van
by ram_man - 07/03/20 07:22 PM
original '05 Chrysler trans pan gasket material ?
by visitor - 07/03/20 06:16 PM
rock auto can't ship to Calif????
by 928 - 07/03/20 06:04 PM
2001 Silverado 1500 T-Case Fluid
by Blang - 07/03/20 05:53 PM
Nasty Car wreck
by ford46guy - 07/03/20 05:53 PM
Best style of condenser?
by ddeflyer - 07/03/20 05:17 PM
Advance Auto now selling Die Hard Batteries
by Kira - 07/03/20 05:01 PM
Ontario Nuclear update - Part 2
by OVERKILL - 07/03/20 04:36 PM
Is this totaled?
by NoNameJoe - 07/03/20 04:23 PM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
55 registered members (Astro14, AlienBug, BAJA_05, 94astro, AndyB, alarmguy, 4 invisible), 1,077 guests, and 24 spiders.
Topics307,398
Posts5,310,374
Members71,843
Need a good exhaust manifold for my Truck #5465190 06/28/20 08:50 PM
M
Miller88 Offline OP
M
2001 F350 with a 2 valve 5.4 in it
So April of last year and 3000 miles ago I had the passenger side exhaust manifold on my F350 replaced. I managed to blow it out again with a pretty big crack. I will admit that I was running the truck pretty hard, but it seems a bit odd that with 3000 miles (probably 1500 of them towing) it would blow out. I didn't even drive the truck in the winter!
When I had this one put on, there weren't any big name or good manifolds for it. I ended up getting Dorman because that was the most expensive. I figured quality would be better than the cheapies. Not the case ...
I don't want to go stainless headers for a few reasons. First, this truck is not worth that. Second I believe the loss of scavenging would be counter productive to towing.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Need a good exhaust manifold for my Truck [Re: Miller88] #5465200 06/28/20 09:02 PM
T
Timmastertech Offline
T
Ford manifolds are less than 100 bucks each. Thats what we install in our shop. The aftermarket manifolds dont last. We also use genuine ford gaskets because I dont like the aftermarket designs. Need 2 gaskets per manifold from Ford
Re: Need a good exhaust manifold for my Truck [Re: Miller88] #5465202 06/28/20 09:05 PM
A
andyd Offline
A
Cast iron? Would brazing the crack work?
Thick oil is better grin2
Re: Need a good exhaust manifold for my Truck [Re: andyd] #5465205 06/28/20 09:11 PM
M
Miller88 Offline OP
M
Is the Ford dealer the only place to get those? I had tried to find a Ford manifold but couldn't.
It's cracked on the inside so it would have to be taken off. Tempted to try furnace cement.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Need a good exhaust manifold for my Truck [Re: Miller88] #5465210 06/28/20 09:17 PM
Z
Zaedock Offline
Z
When I had my shop we replaced a bunch of these. Always used dealer manifolds and never had a return.
The 5.4 2V engines are fine (if you have more than 3 spark plug threads) but the manifolds remind me of 4.0L Jeep manifolds with the cracking.
If it were mine and I could access the crack, I would prep, pre-heat and use high nickle rod and zap the crack up.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: Need a good exhaust manifold for my Truck [Re: Miller88] #5465396 06/29/20 06:57 AM
M
Miller88 Offline OP
M
Mine is a 1997 F150 engine, so it definitely only has 3 threads!
Luckily my Jeep 4.0 is a 2000 so it has two exhaust manifolds. That and the distributaries ignition are the main reasons I got a 2000
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Need a good exhaust manifold for my Truck [Re: Miller88] #5465478 06/29/20 09:08 AM
supton Offline
I think you should unbolt the manifold and slide a different truck under it. At some point you need to stick a fork in it and call it done.
Maybe buy the OEM manifold (I'm surprised it's so cheap) and sell it while you can...
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: Need a good exhaust manifold for my Truck [Re: Miller88] #5465487 06/29/20 09:25 AM
Schmoe Offline
Wow. Had the exact same problem on my F150 with the 5.4 about two years ago. The stud cracked inside the heads. Had to have that drilled out...that was no fun. Not sure which manifold I put back on. Seems to be quite common on that engine.
01 Supercrew Lariat 4X4
06 Accord EX-L V6
2018 CRV EX-L
2017 Accord Coupe V6 EX-L 6AT
Re: Need a good exhaust manifold for my Truck [Re: Schmoe] #5465882 06/29/20 07:13 PM
M
Miller88 Offline OP
M
Might be a broken stud. I can feel pretty bad rot / blow out around the back side but a broken stud wouldn't be out of question. Especially with no transmission mount things really bounce around
I'd like to unbolt the tags and slide another truck other. I've been trying pretty hard to get a different truck, but everyone is bored and buying every used vehicle out there.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Need a good exhaust manifold for my Truck [Re: Miller88] #5465918 06/29/20 08:19 PM
T
T
Yeah, call down to the local FOrd dealer with the VIN and they should have it in stock. Around here, every dealer has at least one of each manifold in stock
